Question about Price Pfister Plumbing
I have a Pricepfister 26 series Cadenza for kitchen. Water was running fine when pressure went down to about 1/4 . Thought it was the cartrage, replaced cartrage, still running about 1/4 the way it s
Replaced cartrage still runs about 1/4 the way it should
  • 50 Answers
SOURCE: FF-1800 HAS LOW HOT WATER PRESSURE AND DELAYED TIME TO GET HOT
Sometimes there is a lot of sediment released into the pipes (particularly hot water) when water lines are shut down and restarted as part of a remodel process.
Particularly with a pressure balanced faucet this can create all types of symptoms including those you describe...
Before you go to any expensive lengths, check any intake screens or strainers, both on the faucet and in the other components of the system. A lot of the time this will solve the problem...
Posted on Jan 05, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
  • 129 Answers
SOURCE: I have a pfister 536-e series Pfister/catalina
First unscrew areator from faucet spout, you might need pliers for this. Make sure the areator is clean, sometimes sedement from water lines can slow water down.
Posted on Sep 28, 2009
  • 21 Answers
SOURCE: kohler forte single control kitchen, low colder water pressure
1. If it is old enough, it is time to replace the control cartridge.
2. Check your supply stops under the counter, check that they are both supplying full pressure.
Posted on Nov 16, 2009
  • 409 Answers
SOURCE: I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Posted on Mar 11, 2010
Faucet works sporadically even thought solenoid is disconnected
You are saying that the water comes on by itself? What water pressure do you have?
Apr 08, 2016 | Delta Pilar Pull-Down Single Handle...
945 Kitchen Bridge Faucet - Swivel Spout, 9-1/2" (no Han) Brand: Newport Brass NB945-26 Series: 900 The stem moves up and down slightly when I turn on/off the water pressure. It does not leak but...
There is a good chance that if you remove the handle there will be a retainer of some sort. The retainer's job is to keep the stem/cartridge from pushing out due to water pressure. It may be in the form of a nut or a clip. Be careful removing the handle because if the retainer is completely disengaged then the stem/cartridge may shoot up. Turn the hot and cold water off at the valves located under the sink and relieve the pressure by turning the faucet on. If it's a loose nut it will spin freely. Tighten it. If it is a clip you may need to play with the stem/cartridge to align it properly before the clip will move into place..
Jul 15, 2011 | Newport Brass Plumbing
The top fell off the faucet, doesn't this faucet have a life time warrenty
Price Pfister Marielle Kitchen Faucets Do come with a limited lifetime warranty from Price Pfister-to the original home owner. You can contact Price Pfister on line at www.pricepfister.com, call them toll free at 1-800-PFAUCET or Email. The faucets warranty can be downloaded at http://www.pricepfister.com/support/warranty.aspx.
Sep 28, 2010 | Price Pfister Marielle Kitchen Faucet with...
Kitchen sprayer/diverter
http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/marielle/mar026-4n/26548-0500.pdf
Page 2 on this web site has the diverter listed. Sounds like the diverter is sticking or hanging up and not working right. The link below has information on the faucet you have so I hope this will be helpful for you.
First you could take it off and clean it and check it out for any blockage.
http://www.pricepfister.com/product_catalog/document_search_results.aspx?doctype=15&room=kitchen&collection=Marielle
Jun 05, 2010 | Price Pfister Marielle Kitchen Faucet with...
Flow is very weak - less than 1 gpm. Ewplaced
There are little rubber restrictors in the stainless supply hoses you can pry them out with a small screw driver
Nov 10, 2009 | Price Pfister Marielle Kitchen Faucet with...
Why do I have low pressure on sprayer and still have water coming out of faucet when I am spraying.
Get the replacement parts in about 10 days FREE from PP. Call 800-732-8238. The flow is the diverter tee. I had the cartridge and aerator replaced. And then I replaced the diverter tee. I ordered the parts on a Saturday; got them the following Saturday. Below is a video to remove the diverter tee. The video is helpful, but doesn't tell you about the other 2 connections. The "spout" connection and the connection to the right (the "t" part) is simply a wiggle off. Then after those are off (with lots of water coming out - get towels ready), then you can crawl back from under the sink and get the sprayer off. The sprayer procedure is in the video (push up/in hose) then pull down gray collett. These faucets were discontinued in 2005; a plastic disconnect is now available for newer models. Also, we had to replace the cartridge and the aerator to keep it from leaking out of the handle. The problem we originally had was not having equal pressure with the faucet and the sprayer. The faucet would be running and then the pressure would go down. The sprayer would be weak when the faucet was on - never getting full pressure from the sprayer, just a trickle. It was "moody."
26 Series:
Removing Diverter/Quick Connect:
Dear Customer,
Thank you for contacting Price Pfister, here is a link to a video that will guide you through the steps on how to either remove the quick connect or the diverter.
http://www.pricepfister.com/about/diverter.aspx
You can go to PP's website and see and "Exploded View" of the model you have. If in the model number it states "XX" that is the finish - for example, mine states Marielle Kitchen Faucet "26-3NXX" The "3" is the number of holes (put a 4 in its place for 4 holes). The XX is SS for Stainless steel - even though it's chrome.
Oct 29, 2009 | Price Pfister Marielle Kitchen Faucet with...
I have a pfister 536-e series Pfister/catalina colletion kitchen faucet. Low water pressure from both the hot and cold water. How do I fix the water pressure? Water pressure in the rest of the house is...
Sep 27, 2009 | Plumbing
Aug 31, 2009 | Plumbing
Parts came out of diverter, need help putting them back
The valve went in with the flat brass end showing and the o-ring on top of that. I went to the store and found the same model so I could see the part and how it was assemble.
Jun 13, 2009 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
61 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
