Question about Locks & Locksmithing
Door deadlocks I can't use the key on the outside to unlock the door, but works fine from the inside
  • Anonymous Jan 25, 2009
    speaker key not working I can hear them thay can hear me
    Problem Solver:
  • 16 Answers
Take the lock apart & rotate the flat metal actuating rod 180 degrees & re-assemble the lock.
Posted on Oct 27, 2008
The round metal piece outside the door where the key is inserted to open the door of my Lockwood deadlock is loose, how to tighten it please
go to the inside of the door and tightened the 2 screws from the back that holds the lock in the door.
Jan 12, 2015 | Cars & Trucks
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
Opening the drivers door doesnt automatically open the passangers door
Some vehicle locking systems allow a single button press to unlock the driver's side door and require a second button press to unlock the passenger side door. Likewise, use of the key to unlock the driver's side door does not automatically unlock the passenger side.
Mar 25, 2014 | Dodge Stratus Cars & Trucks
Key won t turn door lock
spray inside the lock work key in and out tumbler probaly stuck if it works get some graphite for lube
Jan 30, 2014 | Toyota Cars & Trucks
How to open a deadlocked rear door.
Hi. remove the rear seat and door pad. You can access the lock through a small hole, break the top inner corner of the lock and it will release the dead lock and open the door.
Jan 29, 2014 | 2004 Volkswagen Golf
Driver door wont open
You probably either have a piece of linkage that has come loose inside the door or the latch mechanism is stuck halfway between "lock" and "unlock" (fairly common on some vehicles). You will need to remove the driver's seat to make room to work so the driver's door panel can be removed if you cannot open the door from either the inside or the outside.
If you can get the door open, then the door panel should be removed to inspect the linkage and latch mechanism.
Feb 11, 2012 | Cars & Trucks
Three Doors Deadlocked on VW Golf 1999 model
actuators working on all four
locking module could be out of sequence after the one door repaired
drop the vw back into the place where the door lock was replaced
get them to explain
Mar 26, 2017 | 1999 Volkswagen Golf
Locks & Locksmithing Logo
216 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
