Question about Uniden Cordless Phone
Motorola l630m will not register handsets
I have a Motorola L404 cordless phone. i bought an additional handset. I cannot get it to register with the base unit. It just keeps saying "registration failed"
On the Motorola L404 series, to deregister all handsets you unplug both the phone and power to the base station. Press and hold the 'find' button while plugging the power back in. The display will show "CL". Continue to hold the find button till the display shows '00' and all the handsets will show 'unregisterd'. You then proceed by registering all your handsets again in the order you want them listed.
Sep 01, 2010 | Motorola Mobility L4 Cordless Expansion...
Can't register Motorola handset.
There is a very little that we can proceed to here, as these phones are known for the problem that you are facing & most of the customers that I have myself seen ... finally get rid of them buying new ones,
Let’s try resolving it though;
1.) Open battery compartment, remove battery. Also remove belt clip on back of phone. You might have to pry it a little.
2.) Pop off the access panel on upper back of phone. This panel merely hides two screws.
3.) Unscrew all visible screws, Separate front and back of phone. You might have to wiggle the pieces relative to each other. The rubber strips on the sides are held in place with dovetail grooves.
4.) The phone should come apart in three sections.
5.) At this point, get some cotton swabs and alcohol. Dip a swab in the alcohol and rub down the contacts on the keypad and little black pads underneath each button on the rubber membrane.
6.) Let it dry and re-assemble. Your phone should now work properly.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 21, 2009 | Motorola Mobility MD41 Expandable Handset...
How do you unregister a defective handset so that it can replaced
1. Delete or listen to all voice mail messages, if necessary, to clear the IN USE/Voice Mail light indicator.
Note: Skip this step if it does not apply to your MD Series cordless telephone model.
2. Press OFF on the base station and each handset.
3. Press and hold down PAGE on the base station until the IN USE light flashes slowly, then release.
4. Press and hold down PAGE again until the IN USE light begins to flash quickly, then release PAGE.
5. Quickly and fully press and release PAGE again.
6. Please register handset displays. Press OK to begin the registration process, or press EXIT.
Dec 10, 2008 | Motorola Mobility MD41 Expandable Handset...
Registration problem
download the user manual from the motorola web site for your model
May 27, 2017 | Motorola Mobility Lands Phones
Registration
Hi Tom
Can you please tell me what the model of the expansion phone. I may be able to research anf find you the correct procedure for resistering a new address number to the phone.
Thank you
Greg
Nov 03, 2007 | Motorola Mobility MD761 Cordless Phone
PROBLEMS with phone
Had the same issue. I have two units each with a handset, and one handset went to "out of range" status and stayed that way even after recharging. I tried to register it with that base and no luck. I then tried to register it with the other base and it worked. Then I tried to "swap" the handsets and no luck - it seems that the registration process on the one unit is toast so now I can only use the handsets with one of my two base units.
Oct 22, 2007 | Motorola Mobility MD7091 Cordless Phone
Registering handset problem
worked for us AFTER plugging/unplugging the base unit. thank you!
Feb 11, 2007 | Motorola Mobility MD761 Cordless Phone
Won't register
hi follow these steps and you will so great:( page 8) http://broadband.motorola.com/consumers/products/md7001/downloads/MD7001_Series_Users_Guide.pdf wont work try deregistering and then register again good luck
Apr 09, 2006 | Motorola Mobility MD7001 Cordless...
New Expansion Handset refuses to register with the base
If im not misytaking the base has to be set up for another expansion too.
Apr 06, 2006 | Motorola Mobility MD7091 Cordless Phone
Uniden Cordless Phone Logo
132 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
