Question about Altec Lansing ACS 45.1 Computer Speakers
Static electricity shock blew a circuit for the speakers. The power light is on, but no sound.
I touched the buttons to turn off the power and received a static electricity shock. Now the power light comes on, but no sound comes from the speakers. What happened?
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll to sounds video and game controllers ther might be a yellow question / exclamation ? ! mark or a red X right click to update driver
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Posted on Feb 14, 2012
2 Suggested Answers
MPetro302
  • 298 Answers
SOURCE: Loud static sound comes from computer speakers and the phone
Uninstall and reinstall new drivers for your sound card from the soundcard manufactures website or if its onboards from the PC makers site. If your using vista their has been widespread issue's related to the static "bug" and numerous solutions that sometimes work or do not work have been tried. ex; if is a soundblaster card try Creative.com's forums.
Posted on Apr 16, 2009
I have a panasonic pt-56lcx16 and it needed the bulb replaced, i got a new one and installed it. I turned on the power button on the tv, then it makes a electricity sound where the bulb is but doesnt come...
If the electricity sound was loud and static sounding then you had a short with arcing which is not good and you blew a board or the socket that the bulb went into. Check that there is current at the bulb fitting.
Mar 02, 2014 | Televison & Video
My X46 only turns on by the remote but when it does turn on it only goes to the Sceptre screen then powers off again. When I shut it off the night before there was a static shock when I hit the power...
That little shock has between 500 to 21,000 volts. Sensitive transistors and microchips definitely get damaged permanently from static electricity.
Jan 22, 2014 | Sceptre X46BV TV
I touched my speaker and felt a static electric shock, the unit powered down, although it powers up, I hear the cooling fan but no sound or front power LED now. what happened and how do I fix it?
Did you have this speaker AND the device that drives it connected to the same power source? If run by a mixer you MUST run a power extension from the same place your powered speakers are powered to the mixer. Ground bounce due to wiring in a building can destroy input circuits due to ground faults and static discharges. ALWAYS use balanced lines either XLR or TRS cables to interconnect the audio.
Also verify your power receptacle is properly wired. Carry one of those plugs with the indicators showing receptacle is wired correctly. Don't plug anything in until you verify it. Some venues are noted as having bad electical service.
Let your speaker sit for a minute and repower it... sometimes they have a lockout that takes time to reset.
Mar 03, 2011 | Mackie HD1531 3-Way 15" HD Powered PA...
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
Jul 11, 2017 | Emerson EWL3706 37 in. LCD Television
There is static coming out of my speakers on my stereo. I I checke to make sureall the wires are connected properly and the power is plugged in securely. There is static with the sound on all...
Don't worry, it's more possible that you have the static electricity and through your stereo this electricity goes to the ground. Try touching another metalic surfasce (refrigirator, oven etc), try to change your shoes (especialy if your stereo is on a carpet floor and you walk on it) Sometimes when we are very nervous the static electricity on our body is higher. So keep calm.
Stelios.
Feb 20, 2010 | RCA WSP155 Main / Stereo Speaker
Have iLive ihs3 2.1 speaker system. The speaker was sitting on top of the television, roommate was dusting the tv screen and elbow touched iLive speaker. There was like a static electricity shock, and...
Unfortunately I don't think so. TV"s can develop a huge static charge & dusting would increase it... that Discharge was a huge shot of Static Electricity, most likely fried ya output devices...
Feb 02, 2010 | Audio Players & Recorders
My yamaha reciever has a power problem in that when i switch it on, it only goes on for a few seconds and thereafter goes off.
As long as you're sure the power cord is firmly plugged in, it sounds like the protection circuitry of the unit has likely been activated. This happens when there is a short circuit in one of the connections. Check your speaker wiring connections and make sure all of them are firmly and carefully grounded (i.e. the copper of the wire touches nothing but the proper terminal, and that the wires do not touch each other). Check the connections on the speakers as well. If protection circuitry is the result of a shock or power surge (lightning, strong static, etc.), you can reset it. Turn it to standby mode, unplug it, wait for 30 seconds, then plug it back in.
Jan 20, 2010 | Yamaha HTR-5630 Receiver
I touch the on/off button on the Prima TV to turn
I am sure you had some strong static electricity. The static spark arced to inside of the TV in to the circuit board. Many of the low cost TV sets have poor static electricity protection.
In most cases there is damaged caused by static shock to electronic devices.
Just for curiosity, you can try unplugging the set from the AC mins and plugging it back in to do a simple reset, in case there is no damage and some logic device became hung up.
Last year I picked up my mobile phone and got a static shock from it. I had to get a new phone. This phone never worked again!
Jerry G.
Jan 19, 2010 | Prima C2012 TV
PS 2 shocked me when I was turning it off. Now it won't turn on.
When you experienced that shock you may have inadvertenly sent an electro static discharge to the circuitry inside the ps2 which would cause it to stop working.
 If it is fairly new return it to the store you purchased it let them know whar happened and usually they will exchange the item for you.
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
Sony KP-43t75 - Front panel buttons and IR sensor stopped working
TRY UNPLUGGING THE SET FROM THE WALL FOR 2 MINUTES THIS WILL ACTIVATE THE AUTO RESET WHEN YOU PLUG THE SET BACK IN.
Dec 28, 2008 | Sony KP-57WS500 57" Rear Projection...
Altec Lansing ACS 45.1 Computer Speakers Logo
168 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
