Question about Miele Novotronic Premier 500 Front Load Washer
Miele Premier 500 (W504) Washing Machine not heating water
I purchased a Miele Premier 500 washing machine (used) about 3 months ago from a repair man who replaced the heating element. Up until last week it was ok until it started tripping the fuse. When I tried it again the drum was turning and after a couple of mins I noticed smoke coming out of the drum and a smell of electrical burning. The guy who sold it to me said it must be the heating element. I've taken it apart and could not find any burning or pitting on the element. I put it back together and now it's not shorting out the fuse but the Main Wash light keeps flashing (it seems to go through the wash cycle) but does not heat the water.
I also noticed (before this hapenend) that the wash cycles were taking longer than what the manual stated.
I am a little nervous about spending money on a new element if there could be something else wrong. Why would the element go after 3 months? Could it be the NTC sensor? or something on the board itself? I am going to get hold of a multimeter to test the components but I'm not an electrician and don't really know what to do or how to tell if a component is faulty.
Does anyone know what could be causing this ? or can anyone advise on what steps I should take to test?
Many thanks
Zenon
3 Suggested Answers
SOURCE: Miele Premier Novo Washing Machine
Open drain door at bottom front left of machine. Pull yellow tab that is there. This is the manual door opener.
Posted on Aug 22, 2008
  • 70 Answers
SOURCE: miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Posted on Apr 01, 2010
Testimonial: "thanks, you confirmed what we sort of expected"
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
How do I open my Miele W504 and change the motor brushes
Hi Kieron
Open door then turn off power. Undo 3 bolts around door seal. Remove soap draw. Undo the screws. Peel off door seal at front of machine and fold in towards drum. Metal spring catch located at bottom behind pump filter door. Now open up front of machine (its hinged on the right). Good luck
Feb 19, 2012 | Miele Novotronic Premier 500 Front Load...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Washing machine not spinning
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section appliance will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent ( Y - Piece) from drain pump blocked.This requires front panel to be removed.
If the machine detects a fault then an indicator light will flash,(rinse light for motor circuit).
Apr 22, 2010 | Miele Novotronic Premier 500 Front Load...
Miele premier novo, the main wash light flashing
Hi
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Wate rleak Miele premier 300
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Jul 28, 2008 | Miele Novotronic Premier 500 Front Load...
Jul 15, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
416 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
