Question about Buffalo Technology Computers & Internet
Windows 7 won't recognise buffalo hd-ce1.otu2
I used to run windows xp with my buffalo, now I have a new windows 7 pc and it does not recognise it. How do i resolve this ?
  • 8 more comments
  • Trevor Pegler Feb 14, 2012
    Every so often I see a message asking me to re-format the external storage device, which presumabley I do not want to do as I would loose a considerable amount of stored data.
  • Trevor Pegler Feb 16, 2012
    Brian
    I have been through your recommendations, and when selecting computer devices and disk drives I see no yellow question marks, red x or exclamation marks.
    It sees the buffalo hdd usb device and I have right clicked and updated the latest driver, but I still do not seem to be able to access the drive.
  • Brian Sullivan
    Brian Sullivan Feb 16, 2012
    if you have not got any yellow or red marks all drivers are up to date and it should be working properly
    Brian
    Only have 'General' and 'hardware' tabs available when I rt click on Buffalo tab - no others.
  • Brian Sullivan
    TIP: here is an easy way to get all control panel items in one list
    in the bottom toolbar right click select toolbars then select desktop
    you will see a destop>> in your toolbar click on it then control panel all control panel items you will see a list of all control panel items
  • Trevor Pegler Feb 17, 2012
    I have now tried properties, volumes and populate, but there were no sign of any mb's or gb's. The pc did do something so I went back to add a device as suggested but still no joy.
    I have also been back to devices and printers and on selecting 'sata bridge' and asking it to browse files it says 'cannot access 'incorrect perameters'
    By the way the pc is a hp P6-2010 with I presume standard windows 7 home pro.
  • Brian Sullivan
    Brian Sullivan Feb 17, 2012
    you can see your Buffalo hard drive but cant access it
    click start control panel system and security click on find and fix problems under
    hardware and sound configure a device next it will search for possible problems
  • Trevor Pegler Feb 19, 2012
    Brian
    Thanks for coming back to me
    I found find and fix problems under the 'action centre'
    After initiating 'configure a device' it came back with 'troubleshooting has completed' and under problems found it said 'hardware changes might not have been detected' - detected
    It then prompted me to try the device again.
    I then went to devices and printers - browse files
    an it came back 'cannot access files corrupted and unreadable'
    So still no joy
  • Brian Sullivan
    Brian Sullivan Feb 19, 2012
    since you still cant get access to your buffalo drive im not sure that the corrupted/unreadable files are the ones on this device
    you might need to install a usb 2 or 3 card they are cheap and almost install themselves if using a desktop with a spare slot you can get them on Ebay cheap or you might need firmware update http://www.buffalotech.com/support/downl...
  • Trevor Pegler Feb 20, 2012
    Sorry Brian, I do not know what a usb2 or 3 card is or how it works.
  • Buffalo Tech... Master
  • 27,725 Answers
You might back up your data to another drive if possible
then format your buffalo drive then transfer it back
i have had similiar issues with xp and w7 using usb drives and have found that i have to designate certain usb drives to the computer running windows 7 and same running xp
if i try to use the one designated to windows 7 in my xp get this drive is not formatted do you want to format
although these drives are not buffalo just usb data drives but of large capacity 128GB
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Feb 15, 2012
  • 1 more comment
  • Brian Sullivan
    right click on your buffalo usb drive select properties you should see an array of options general tools hardware sharing ready boost and customize
    under the sharing tab advanced sharing make sure you have share this folder ticked then permissions make sure all boxes are ticked to allow you full control
    also you might click on the customize tab then restore default
    in windows 7
    Brian
    Only have 'General' and 'hardware' tabs in properties - no sharing, ready boost or customise.
  • Brian Sullivan
    that seems odd which version of 7 are you using home pro or ultimate
    right click on your buffalo select properties select the harware tab select your drive
    properties then volumes then populate
    you should see it populate to how many mb's gb's are used and available
    also you might
    click start control panel add a device and follow the prompts
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
I have a 1tb Buffalo HD-PCU2 ministation. I want it formatted as Fat 32 to use on my Humax recorder but Windows vista or 7 don't recognise it? Is it fixable?
FYI: fay32 doesn't support files larger than 2GB so if your putting movies than do NTFS.
To format as FAT32 you have to open an command prompt as admin. Window Button > All Programs > Accessories > Right CLICK command prompt and run as admin.
<VOL> = your drive letter ex E:
Command to format as FAT32
format <VOL> /FS:FAT32 /X
Dec 22, 2012 | Computers & Internet
Have recently had to add windows 7 to my PC (losing everything) but have laptop using XP. When I plug buffalo ministation into PC it wants to format but I'll lose everything on harddrive won't
click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
hope it helps
Oct 12, 2012 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
I can,t record t.v on my buffalo Hd-lb1.otu2 uk external harddrive on my Panasonic tx-p55vt30
the hard drive MUST have a certain type of file to record(save) and your file may NOT be compatible check specs and then you might find answer
May 28, 2012 | Buffalo Technology DriveStation Computers...
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
Will Buffalo Model HD-PE250U2 work with Windows 7 OS? Regards sandra
Yes, it is a "plug-and-play" device, and Windows XP/Vista/7 support "plug-and-play" devices.
Dec 31, 2010 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
Im using buffalo external hard disk. HD-CE1.OTU2. but when i connect to my laptop it shows 'you have to format this hard disk before you can use it" and it is vry slow when i use it n it always not...
Theres a few different types of filesystem the main ones being betwwen Linux and Windows system theres even new ones that are just coming into popularity--so reformat must be with correct type
Sep 07, 2010 | Computers & Internet
Sybase Powerdesigner 9.5 Windows 7
PowerDesigner 9.5 wil load on Windows 7 but it won't run. I was able to get it to run by installing it in the virtual XP environment on Windws 7.
For this to work,
Must be running Windows 7 Professional or better, and
Your machine has to allow virtual machines (BIOS Setting).
You will need to download 'XP Mode' and indows Virtual PC' from Microsoft.
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
You will be able to run PowerDesigner 9.5 and oter applications that will not run in the Windows 7 environment but ran previously in the XP environment.
Mar 15, 2010 | Sybase Powerdesigner 9.5 (20330-01-0950)
Computers & Internet Logo
401 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
