Question about Kenmore Kitchen Ranges
Replace oven element - Kenmore Kitchen Ranges
    Scholar:
  • 51 Answers
Depending on the age, model and manufacturer of your range, which I'm assuming is electric, it's fairly easy.
Most electric range ovens have the heating element that curves around to distribute heat, terminating into two leads within an insulated ceramic plug fixture. There are usually clips to hold the plug fixture into the plug, and typically some sort of clips to hold the upper broiling element in position.
If there is a lot of build-up within your oven, you may find it useful to clean it a bit near the plug, so that you can get to any clips which might be hidden.
Be careful not to flex the new element too much, as to cause any cracking, when replacing it.
I hope this helps! As always, more information up front provides better insight and solutions.
Posted on Feb 13, 2012
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Tip
How to Replace an Electric Oven Element
Replacing an oven element is quite simple that almost anyone can do it.
  1. First pull the oven away from the wall and unplug it.
  2. Next, remove the rear panel from the oven.
  3. Now disconnect the element from the wires that power it, they should pull straight off of the element.
  4. Remove any screws that might be holding the element in place, check both in the oven and on the back. It depends on the make and model where the screws may be.
  5. Last, remove the element by pulling it out through the heating chamber, and replace with the new element. Simple as that.
For replacement parts, check repairclinic.com which I recommend, otherwise local stores may have what you need or the manufacturer themselves.
Congrats, you have just learned how to replace an element.
on Jan 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag electric oven model cwe5800acb. The lower element in the upper oven will not heat up. Can the lower element be replaced without removing the oven from the wall.
Yes, replace the lower element by first turning off the circuit breaker to the oven (110V is still to half of the 220V element circuit even though the oven setting is turned off), then unscrew the two screws holding the element to the back wall of the oven, then pull the element out (may have to tug it a bit to get the connectors through the insulation), and pull the wire connector clips off the element.
Mar 14, 2011 | Maytag CWE5800A Electric Double Oven
Oven doesn't go on.
Hi.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace the element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
Mar 04, 2010 | GE Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
Smeg oven ss336-5 not heating
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jan 21, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Black & Decker Toaster Oven Model TR01000-TRO4000
I honestly believe that the burned element in my toaster oven is replaceable
like a burned out oven element or dryed element. I thought someone would
show me how to replace the element. That didn't happen. I am dubious
about the need for experts via a commitment to a specialists' plan.
Peter Olevnik
Dec 15, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Smeg oven and hob ubit: Fan works but oven wont heat up
Oct 05, 2008 | Smeg Kitchen Ranges
Whirlpool oven heating element
Are you trying to replace the stove top element, or oven element? For the stove top element, just lift up the side opposite where it plugs in and pull straight out.
The oven element usually have one or two screws holding a plate in near where the elements go into the back of the oven. Remove the screws and pull straight out. Reverse the procedure to install a new element. The top broil element will be secured in with a couple brackets to hold it up, these must be unscrewed, removed, and then pull the broil element out.
Remember to turn off power to the range before replacing any of the elements.
Aug 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Kitchen Ranges Logo
360 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
