Question about Refrigerators
GE fridge model GSL22JFXA water dispenser is no longer dispensing water.
Water dispenser has stopped working with no warning. I can still hear the tiny electric hum of the pump trying to work, but nothing comes out.
  • mohawkwar738
    mohawkwar738 Feb 19, 2012
    Yes. I change it regularly. A new filter does nothing.
Have you change water filter lately?
Posted on Feb 13, 2012
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
RescueTech
  • 145 Answers
SOURCE: GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Posted on Dec 13, 2008
  • 744 Answers
SOURCE: ice dispenser not dispensing ice or water
Check the water filter - it should be at the bottom of the fridge - turn it 1/2 turn to the left. After several months of use (less if you use it a lot) the filter can clog.
Posted on Jun 24, 2009
SOURCE: ice maker not working bosch refridgerator
Had the same problem. If there is ice in the bin make sure the ice bin is in all the way. there is a
drive gear in the back that has to be engaged. If the
bin is emty open the little door where you can see
if there is ice, on the left you will see the square
end of the ice maker unit. Slip your fingers under
the front face, palm of your hand facing up so you
can feel the bottom of the front of the unit. Over
to the left you will feel a button that you can not
see. Just push it in for a few seconds and the unit
should start. One other thing, make sure the limit
switch is pulled down, thats the plastic on the
wire which shuts the unit off if it is full. Good Luck.
Posted on Nov 01, 2009
aasc
  • 1606 Answers
SOURCE: no water is being dispensed from the water
Start by : at the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . Ge also has a dispensor heater , pt # WR49X10173 , with instructions , to keep this freezing from happening again , if this is the problem .
Posted on Jan 20, 2010
Testimonial: "excellent and easy to follow advise"
How do you get the water dispenser on a GE side by side model GSS201EPD WW to work?
Chances are that the=> WR57X10050 Water Inlet Valve has become defective on the dispenser side of the valve.. I am here should you have questions, Thanks John T. Appliance 911
Jun 28, 2015 | GE Refrigerators
Filtered water dispenser not working; water seems to be going into fridge instead
This could be a freeze up in the line or blockage or the filtre is plugged and needs changing. If you go to the website and type in the model number there is a lot of information there as how to service it.
Mar 06, 2014 | GE Q Series GSS23QGT Side by Side...
GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser won't stop. It started automatically and water keeps being dispensed even though we tried pushing the ice button and the lock button. It stopped when I opened the freezer door but would...
I take it this is a G E refrig ? Model number would have helped . If you still hear a hum with door closed , the microswitch behind the dispensor board is bad . Not a computer problem but a simple fix .
Aug 12, 2009 | GE Profile¿ Arctica® Energy...
Water dispenser no longer dispenses water. Ice maker still works
Has it stopped completely or just slowed to a trickle. If a trickle you need to replace the filter. If stopped either the feed line to the fridge has been pinched/shut off or the internal line has frozen, or the valve is no longer functional.
May 25, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE side by side fridge/freezer. Water stopped comming out the dispenser..
Hello.
If your frig only has a dispenser for water, the first thing you need to check, is the shut off valve, which is sometimes under the kitchen sink, and make sure nobody turned it off for some reason.
If you have a frig that dispenses both ice and water, and only the ice is working but you aren’t getting any water, then it is probably the water side of the dual water valve that has gone out. A lot of times the water side of the valve will go out before the icemaker side, because it tends to be on longer due to people filling up glasses and pitchers.
If you hear water running when you try and get water, then you probably have a leak in the water line that goes to the dispenser.
Another thing that is rare is the water will freeze in the reservoir that is behind the crisper drawers in the fresh food compartment. This sometimes happens when it isn’t used enough.
Nov 30, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
