Ups model su3000 short
There was a widespread short of light and down stream presented a short changed parts of the card has a number cnp8 is small and is next to the power cord switched Varistors but wanting to connect the battery begins to make short
MikeNJ1964
  • 398 Answers
SOURCE: No Power on Sony TV
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Posted on Aug 18, 2007
SOURCE: Power Cord
Please let me know when I can get the power cord & AC adapter. I moved and lost them and cannot use my television. Thank you R. Werkheiser
Posted on Nov 03, 2008
asjsa
  • 36 Answers
SOURCE: Liquid spilled on laptop computer keyboard
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
82
Posted on Mar 13, 2009
SOURCE: I spilled a little white wine on my Gateway laptop
Please remove the Battery from the Battery bay and disconnect the AC Adaptor from the Notebook. Then, clean the metal contact in the Battery Bay and leave the Battery removed for half an hour. Next, connect the AC Adaptor to the Notebook and the power cable to a functional wall outlet and try to turn ON the Notebook. If the power LED on the Notebook doesn't glow then again disconnect the AC Adaptor and try removing and reinserting the RAM module. If the issue persists even after performing all the above steps then service will be required.
However, if the Notebook turns on after performing the above mentioned steps but the Battery is not detected then perform C: Drive Restore using the VAIO Recovery Center.
As per the specification published online, the Computer model VGN-N250E is preinstalled with the VAIO Recovery Center in the hidden partition of the Computer. You may use it to perform C: Drive Restore to restore the Computer to the original factory settings. Please make sure that the new Battery is installed in the Computer while performing the Complete System Restore.
Performing a C: Drive Recovery will erase all the data present in the C: Drive only and will reinstall the pre-installed Operating System, Applications and the original Drivers supplied with the Computer.
Please restart the Computer and keep on tapping the F10 key to access the VAIO Recovery Center. Next press the Enter key then select the "VAIO Recovery Center" option then follow the steps given in the link mentioned below to proceed with the C: Drive Restore.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C473668
In the link given above, please click on the sublink "Restore C: Drive" to view further information on performing the C: Drive Restore.
Performing all the steps successfully should resolve the issue.
Posted on Jul 12, 2009
jvpacoin
  • 91 Answers
SOURCE: Back UPS Model # BK200C salvageable?
Yes you right you can just use it as surge protector, but it would be better if you gonna buy a battery for that unit aleast you got a back up in the event of power outage.
Posted on Aug 14, 2009
LG LED TV. 50LN5700UH. Picture out. It will flash LG Logo on power up then go black. Image is present by flashlight test. Audio is also present. Power LED is also lit.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 02, 2017 | LG Televison & Video
Hi I have a whirlpool dishwasher, power is present at stub, thermal fuse is fine, but no power ( lights on control board don't light) otherwise. Cannot start machine. I changed out the thermal fuse
Hello Clinton;
My name is Peter. I am a retired field service appliance technician.
If you have power going into your unit, your display board should light up. You need to get to your control board. Turn power off to your unit, push in on the wires to your connectors, inspect the board for burn marks or melted connectors.
Before you touch your control board ground yourself by touching something that is bare steel. Static electricity will knock out a board. Do the same if you replace the board. The part number of the board is on the board. Do not buy locally. You can get some great deals on the internet.
You did not provide a model number so I can not tell you how to access the board.
Go into the following website, type in your model number and you will get diagrams of your unit for disassembly.
Water Filters Lawn Garden Appliance Parts
Dec 21, 2014 | Whirlpool Dishwashers
O2 sensor is comming up on service engine light warning, auto parts store says that there are 2 sensors on the car. Up stream and down stream. What are the locations for these and how hard are they to...
Hi Steve ..it refers to the location of the oxygen (o2) sensors relative to the engine. The upstream sensor is the one closest to the engine. The downstream sensor is furthest from the engine. Think of it as the way a stream of water, or in this case, a stream of exhaust flows.... From the engine To the tailpipe.
Changing them is no problem, getting to them sometimes can be a bear,, if you can reach them,, its simply remove the old one with a couple of bolts, and unplug it,, and replace
Aug 25, 2011 | 2000 Saturn SL
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
What is the power rating of AP9215?
The AP9215 control panel itself does not have a power rating. It is compatablbe with the following UPS models.
PowerView supports the following APC UPS model families:
Smart-UPS: SU450, SU700, SU1000, SU1400, SU2200, SU3000
Matrix-UPS: all models
Symmetra: all models
Click here for the manual
Hope this helps.
Zeppelinx12
Mar 07, 2011 | APC PowerView AP9215
I have the model FMAC101D1PS and now it's not heating. I press the minutes to heat, it run but it doesn't heat anyting.
Most likely causes are an open thermal protector or thermal fuse but could also be blown fuse in HV area of microwave (somewhat uncommon in domestic microwaves).
Less likely causes are failure of other parts in the HV area.
If the main power fuse is located in the primary of the high voltage transformer rather then at the line input, the clock and touchpad will work but the fuse will blow upon initiating a cook cycle. Or, if the fuse has already blown there will simply be no heating action once the cook cycle is started. There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse.
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact. See the section: See the section: Testing the magnetron (see repair manual link below).
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms. See the section: Testing thermal protectors and thermal fuses (see repair manual link below).
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms.
  • For the various HV parts and how to test them follow this link: Microwave Repair Manual link.
A shorted HV diode, magnetron, or certain parts of the HV wiring would probably result in a loud hum from the HV transformer but will likely not blow the main fuse. (However, the HV fuse - not present on most domestic ovens - might blow.)
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
Oct 21, 2010 | Frigidaire Microwave Ovens
Condensor not working
Did you lay it down? If you did oil may have gotten in the lines. You must allow that oil to drain back down in the compressor before firing up the compressor. Have you checked the thermostat for continuity? If open (no continuity) then power will not go to the compressor or condenser fan motor. I would remove the ADC and see if corrosion was present at the connections and clean that up. Sometimes the harness will short out between control and compressor behind a large area that is covered by a service panel in the rear of the ice box. Just a few ideas. Adaptive defrost manual
This manual shows ow your defrost system works. The parts links above are for the model number you posted.
Apr 22, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Only Sound
Could be the monitor settings don't match the video output or the video card has failed. Try entering the BIOS setup screen at startup. Usually the 'DEL' key held down. If screen is displayed (It will be in default VGA mode at that point), then you know the video stream is OK. Continue booting, and press F8 to enter windows safe mode, and continue from there to get the display parameters corrected.
Jul 24, 2009 | Lexicon Omega Desktop Recording Studio...
Leaking dishwasher
Sorry about the delay in time in getting back to your problem if not already resolved heres what you can try. Remove the bottom panel and run through a load, to see exactly where leak is coming from, most common place for leak is through the heater hold down brass nuts. They crack and need to be replaced
Feb 27, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Amplifier repair
Unknown model not working could be a bunch of things!
does the unit have power?? fuse(s) ok?? turn on voltage present(12v)?? Any leds?? Unit ever get wet?? Any lites?? smoke get out?? was it, did it get real hot??
I have worked on a few with various problems, no common problems. Some of the things I have seen; Level adj pot was smashed in, Shorted fets , + burnt gate drive resistors in the ps section + blown runs, bad connections, shorted outputs, corrosion from beer leakage, bad electrolytic caps, leaking caps ate up the copper runs, metal bars used to hold down fets and outputs came loose, parts over heated and shorted.
Open up and look around, burnt resistors, leaking caps, puffed up caps, black marks, are all helpful signs.
These amps typically use FETs in the power supply(+/- 25-50v) and regular transistors for the outputs. Test all heatsinked parts for shorts. Carefully remove metal bars holding down heatsinked parts, keep track of where the heat sink insulators go, remove pcb and inspect runs. Repair and bench test with a power supply that has an amp meter. With out any input, unit should only use a few amps after initial 5-15amps to get the PS fired up. Then test across speaker outputs for any DC voltage. Anything over 1v, (should be very close to zero) amp needs some more work.
Nov 06, 2007 | Orion 8004 Car Audio Amplifier
Computers & Internet Logo
David Payne
David Payne
