Question about RCA F36665 36" TV
NO PICTURE, JUST A HIGH PITCH NOISE, SMELLS LIKE SOMETHING BURNING
My tv has no picture. I came home turned on my tv, there was no picture, just a high pitched noise and a burning smell. What can I do to fix it?
    President:
  • 3,130 Answers
Very common problem with these sets. The High Voltage transformer and the horizontal output transistor is most likly the problem.. If you know the saftey issues involved and know how to solder and unsolder, you can repair this set but theres a possibility you could also have a fault in the horizontal driver circuit, such as l401. if your not a tech its best to have this set fixed by a trained tech, if you wnt to spend between 175 to 225.00 Good Luck
Posted on Aug 13, 2006
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
Hi I have a very annoying, ear piercing high frequency pitch coming from what seems to be the television. However, I was trouble shooting and based on the cable technicians thought; said to be the...
Hello
The LOT [Line Output Transformer] of your TV has damaged. It is the one, that supply all the voltaged needed to CRT. Its internal windings will get shorted in between, and is irreparable. Replacement is the only remedy to this proble. Replace the horizontal output transistor also with this. you haven't specified whether there is picture with your tV or not. If this high frequency sound is along with picture, there is some loose in the cores of the SMPS transformer, or LOT itsef. If there is no picture at all, and this high frequency sound is there, no doubt; LOT is damaged. OK.
May 22, 2011 | JVC TM-2703SU 27" TV
TV picture compressed top and bottom, then turned itself off
hi i think you have trouble on the power supply section.
Aug 24, 2009 | Televison & Video
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Jan 25, 2009 | RCA F32650 32" TV
TV Picture does not come on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Audiovox FPE3205 32 in. HD-Ready LCD...
High pitch noise...
replacement of the color wheel is an option.. as a technician i dont find replacement all that difficult. finding one too replace it with is the most problem...
May 19, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
No picture, just a high pitch sound
Sounds like the flyback and horz output is shorted.
Nov 30, 2006 | RCA F32672SB 32" TV
RCA F36665 36" TV Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
