Question about Indesit Washing Machines
Cant locate the filter on my Indesit wg1130d washing machine
Not spining out fully
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
SOURCE: Washing Machine not draining
same thing happened to me but the obstruction was in the hose at the back of the filter and coudnt be seen in the filter. i paid 150euro to engineer to fix this. i watched him fix it and can do it myself now. they rob you for something that is so simple to fix.
Posted on Sep 26, 2007
  • 1294 Answers
SOURCE: Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Posted on Dec 01, 2007
Yozzer6821
  • 116 Answers
SOURCE: INDESIT Washing Machine
Probably the pump or hose is blocked, remove the cover along the front bottom, of the machine, remove the filter and clean out, ensure the pump impeller is clear of debris and rotates freely.
refit the filter and try again.
Posted on Apr 18, 2008
  • 1294 Answers
SOURCE: Indesit WG820 no power in spin
For your model I hope you will find the filter, seen similar models. Disconnect the machine from the mains outlet. Below the door, there's a plastic cover full machine width. Just remove it and on the right you'll see the filter. Unscrew the filter counter clockwise, clean it, check the pump blades and inlet for some foreign objects and screw filter back on.
Posted on Jun 01, 2008
Indesit wib111 leaking from pump
This that unscrews is a filter cover, it does have to come out and will be restricted by something thats blocking it, without being too forceful it will have to be removed so the "catch area" can be cleared of objects, like pins and maybe a sock, then the cover can be screwed back in and made secure to stop it leaking (engineer of 20 years experience)
Aug 29, 2012 | Indesit Washing Machines
Indesit WDL 126 dryer - at end of cycle not draining or spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 11, 2011 | Indesit WA 125 Front Load Washer
Machine doesn't discharge fully
check that the out let pump filter is clear first,, then check that the drain pump is working,, it may be blocked up or stuck so it cant turn or maybe the drive motor has burnd out or the drain away pipe could be a little blocked up
Jul 01, 2010 | Indesit WA 125 Front Load Washer
Washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Jan 23, 2010 | Indesit Washing Machines
Indesit WG1234T - is there a filter and spin cycle not effective
If there is no filter located at the bottom right front of washer behind a re- moveable cover, then you need to remove the rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should help solve your prob.
Jan 05, 2010 | Indesit W 123 Front Load Washer
WG1130D
if not heating, will stick in cycle.
remove connections from element and check for continuity with a multimeter
Jul 11, 2008 | Indesit W 123 Front Load Washer
Jun 01, 2008 | Washing Machines
Apr 18, 2008 | Washing Machines
Indesit W133S front loader
hi there the filter is at the bottom of the machine behind the kickplate but if you are getting a bad smell it is more likely your machine needs a service wash ie. run some old towles through on a 90 degree cycle with some soda crystals.
hope this is of some help
Dec 07, 2007 | Washing Machines
I have just fixed the same problem. At the front - bottom right is the filter - you may have to remove the kick board on your fitted kitchen to see this - put a small dish under to capture water - unscrew half a turn - drain off all the water - then fully unsrew and pull out - I had money and treads from jeans blocking the filter - clean out, replace filter and fully tighten. My machine worked after this. - Steve
Nov 21, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Chris Hall
Chris Hall
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
