Question about Cameras
How do i program
Put in new access code?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Step 1: Determine the make and model of your camera.
Step 2: Repost your query, being sure to include the information from Step 1.
Posted on Feb 14, 2012
Why is my activation code not being accepted by mcafee. due for renewal
the code you are trying to put in should be only for the new program
old codes will not work for new programs
next , with most security programs you have to uninstall the existing program then install the new one and then put in the code
call mcfee help desk for assistance
May 08, 2016 | Mcafee 2009 Internet Security - 3 User...
Any four digit code works no matter how many times you reset code. how do you erase all codes and start fresh?
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
pb1000programbutton
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
I'd recommend replacing the batteries if you haven't done so yet.
Good luck--and please provide feedback if this helps!
Aug 21, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
How do I change the code on a Kwikset key pad
Here you go....
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
pb1000programbutton
Aug 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
How do I clear (erase) all codes from my Weiser Powerbolt 1000 in order to start with fresh entries? Adding new codes does NOT override/delete old existing codes as page 7 of my manual indicates. I now...
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Good luck, Elizabeth!
Jul 26, 2011 | Weiser Lock Powerbolt 1000 Lock
Change combination, lost book
Here is a link to the complete instructions:
Jul 25, 2011 | Weiser Lock Powerbolt 1000 Lock
I need to reset the code
Jun 22, 2011 | Weiser Lock GED1460X3BR Lifetime Polished...
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
Coding to VCR and DVD
IF not then you should be able to program in Emerson 0591, 0675 for the DVD player
Emerson 0037, 0184, 0000, 0121, 0043, 0209 for the VCR
THe problem arises however, that the vcr and the dvd function buttons are the same, so you can only program one or the other. You need A different remote. I would suggest the 15-2142 made by radioshack. It is the Family 4 in 1 remote, and it has all the functions you need. THis remote is also backlit on some buttons to make it a little easier to see in the dark.
Mar 12, 2008 | Radio Shack (15-2147) Remote Control
Need to program access code into phone line for long distance numbers
Does it work when you press speaker/hook and manual dial same fax number you are trying to program
It sounds like you are adding digit needed for outside line when it is in fact a direct/dedicated fax line, that needs it not (or vise versa).
Are you printing a report of rapid/speed dials that you set to ensure the number you put in is correct?
Nov 05, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
