Question about Baby Gear
Ariston combi boiler keeps showing fault code 5p3
Fault more predominamt when boiler is cold
  • Dave Sep 10, 2013
    Fault most likely pcb.check flame detection probe condition first.
SOURCE: I have an Ariston Microgenus 27 Combi Boiler
I hate these boilers!
If the pump is not circulating change it. If the pump is ok you may have a blockage in the diverter valve
Posted on Jul 05, 2008
  • 7 Answers
SOURCE: Ariston Microgenus 27mffi combi boiler
im an engineer and recently had exactly the same thing with this ariston boiler, i found out it was the the 'air pressure switch', this is a switch which is part of the ignition, it works in conjuction with the fan. when the boiler fires up the air pressure switch makes, if its faulty it can break the circuit mid flow and cause the burner to shut down therefore giving intermittent hot water and heating, theres a possibility that the aps tubes may be damaged as well so ensure they'e condition is good. hope this helps you
Posted on Sep 18, 2008
  • 18 Answers
SOURCE: COMBI BOILER PRESSURE PROBLEM
It sounds like the expansion tank is unable to cope with the expansion of the water in the system. It may have failed or there may be a blockage so water is unable to get to it.
Posted on Jan 04, 2009
SOURCE: no hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Posted on Mar 20, 2009
  • 13 Answers
SOURCE: my ariston micro genus type c boiler keeps going
when was it last serviced?dirt may be a factor,there are many parts that cause this fault in the microgenus so you need someone familer with the product parts playing up could be1.airswitch2motor3flowgroup4ntc you havent mentioned if it needs re-setting
Posted on Jan 17, 2010
Testimonial: "thanks"
I have a 5p3 error code on a class 24he combi.5 year old.checked dtp volts ok.flue is clear.gas pressure fine.lights 3 times then locks out.any common fault with this boiler please?
Google your product brand and model number, and add .pdf to search parameter to locate possible manual which will have brief troubleshoot section, but will not show a service manual.
Resource:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Gene
h
Aug 25, 2013 | Water Heaters
Ariston microgenus he24 fault is e34 but boiler works when front cover is removed
e34 on a ariston is the fan. Boiler fires up with cover off as its getting the air it needs from atmosphere! fan is not running at full speed
Nov 04, 2011 | Combi Centre DX - Mango
My ariston micro genus type c boiler keeps going hot and cold, the heating also switches on and off, any ideas
Jan 10, 2010 | Combi Centre DX - Mango
Ariston A01 fault combi boiler
its not definately the pcb. change the detection sensor first( £3.20p). if this doesnt fix a01 fault then change the main pcb(£145).
Oct 29, 2008 | Water Heaters
Aug 29, 2008 | Combi Centre DX - Mango
sounds like your diverter valve is passing on the boiler, this diverts the heat either to the rads or to the taps, if its passing through the heating chanel it'll heat up the rads- may also be a scaled up secondary heat exchanger, hope this helps you
Aug 21, 2008 | Combi Centre DX - Mango
No hot water help
have a ariston euro combi boiler ,the problem to get hot water i have to turn the heating on to get hot water. but now it only run for a few min then run cold please help
Feb 18, 2008 | Washing Machines
Baby Gear Logo
1,141 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
