Question about Panasonic Audio Players & Recorders
Panasonic DAB radio type RF-DI. fault code F76 PDET displayed on switch on
3 Suggested Answers
SOURCE: panasonic RF-D1 code f76 pdet
Seems to be a problem with a Transistor BD244c PNP. Old problem of 3years plus wich means are the goods fit for purpose as defined by The Sale of Goods Act/ If not even if they are out of warranty you should get a replacement or your money back
Posted on Jul 16, 2008
SOURCE: Panasonic DAB RF-D1 Radio..
The internal 5v battery is flat
Posted on Sep 04, 2008
F76 PDET
Could be a lot of things. Probably the power output transistor or it could even be a bad push to talk switch on your microphone. If you can give me more information it would help
Oct 03, 2014 | Radio Communications
The radio turns off after 1 second after I turned it on. It gives me this code on the display: F76
Is this a panasonic system? If so, one of two things could cause this: the fan isn't turning or the amp is bad. Make sure the fan is clean and can spin freely. If this doesn't fix it, the amp is probably bad and needs to go in for repair.
Dec 31, 2012 | Audio Players & Recorders
I have an old Panasonic SA-HT40 surround sound system. When the unit is powered on the error message "F76" shows on the display and then the unit shuts off immediately. The user manual instructs to un
I have the same problem with my Panasonic model SAHT-40. I get the same code plus popping and shortly reads maximum overload then cuts off. I disassembled my unit and discovered that my fan fails 2 work causing the unit it over heat. I called Panasonic 2 place an order 4 a cooling fan. This model is obsolete they dont even manufacture parts 4 this unit anymore. The closest that I can get with my credit card is Samsung model AH31-00056B cooling fan through Panasonic. I hope that this solution helps all of u out with ur unit!
Nov 30, 2012 | Panasonic SC-HT40 System
I HAVE A SC-HC30DB SYSTEM AND IT'S NOT LETTING ME IN THE DAB MENU,DAB NOT WORKING ALL WORKING OK OTHERWISE.
I had the same problem - you can fix with a system reset. Unplug the unit at the wall and wait 2-3 mins, then plug in and switch on while holding the power button - the display will be blank for at first, but will eventually display '---------------------'. Release the power button and switch the unit on as normal. Press the Dab button and the unit will start to auto-search for channels. Give it a few minutes and you'll be back in action :)
Chris
Jun 29, 2011 | Panasonic SC-HC30 Audio Shelf System
Hi i have a Panasonic surround sound model SBWA15 which is about 5 years old. The machine switches off and displays 'F76' in the display screen. i took it to a repair shop and they say the outputter has...
I have PANASONIC MODEL NO. SB-WA15, the radio works but when i try to work it witht he t.v. it does not come through the speakers. what do i do? i need help before the superbowl tonight!
Aug 05, 2010 | Panasonic SC-HT17 System
Fault code for sa ht 17
Hi,F76 is the error displayed when the fan goes faulty in the unit.
Aug 11, 2009 | Panasonic SC-HT17 System
Aug 31, 2008 | Audio Players & Recorders
Panasonic RF-D1 code f76 pdet
Apr 12, 2008 | Audio Players & Recorders
Panasonic SC-EN17. F76
you wil have to subtitute a tech for a dealer instead.they will be able to help check along the left side of the home page for fixya and try to locate a repairman near you just put in your area code.good luck.
Apr 06, 2007 | Panasonic SC-EN17 CD Shelf System
Error Code "F76"
spoke to a friend at an authorized servicer and he said he has never heard of that code but from what yourm describing its eather the outputs the speakers or the power supply Oh and a sevice manual is availiable at the partstore.com or from the panasonic web site as I've been there. good luck
Apr 10, 2006 | Panasonic SC-PM08 Shelf System
46 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
