I always have problem in starting my ford focus ghia 1.8 TDCI from cold. if its standing for 6-7 hours, it takes ages to start again, most of the time I need jump leads, though battery is fine.
    Scholar:
  • 51 Answers
There are a number of variables within the smaller Ford vehicles, due to their smaller alternators and loads. So, here are a few questions which may help to narrow down the culprit.
Generally, this involves the fuel/air intake or electrical supply to the cylinders.
While trying to start, does the engine backfire a fair amount? If so, the issue is most likely electrical, and this can be caused by a variety of things. Gas-powered engines tend to backfire when the fuel/air mixture isn't ignited by the spark plug before the valve(s) open for exhaust (but not always).
Does the engine sound like it's trying to start, like firing intermittently, but laboring without backfiring until the battery is dead? ...and, are there any other sounds, like clicking or "clunking" sounds prior to the battery going dead?
Electrical:
1) If the vehicle is fairly new, understand the limitations of the electrical system, especially if you added any after-market items (big stereo, large bass box, etc.), which may require a heavy electrical current to power. It could be as simple as having some sort of power disconnect to these devices, so that all of your battery power can be directed to the spark plugs, and perhaps upgrading to a higher output alternator and battery with more CCA capacity.
2) If the vehicle is older, or has high mileage, it could be the electrical distribution to the spark plugs (any number of places this can happen, between the battery, the regulator, distributor/electronic ignition module, etc.). Also, check your battery terminals, because often the corrosion limits current from the battery posts to the electrical system (check the cables, too, where that blue/green corrosion can build up), which can be cleaned (after disconnecting) with a mixture of baking soda and water to neutralize it, or replace the battery cables altogether.
Fuel / Air Intake Mixture:
1) If an older vehicle, check the fuel filter and/or fuel pump, to make sure there isn't something going on to limit the flow of fuel. Likewise for the air intake filter. Sometimes, the automatic adjustment within the vehicle for cold starting isn't working properly, which can cause problems like you're stating, so that needs to be adjusted and/or replaced.
These would be the easier things to check first, and of course a number of other elements could be at play, such as cylinder compression (bad rings), spark plug build-up (usually from misfiring, requiring spark plug cleaning or replacement), major fuel/air intake or electrical system malfunction.
Unfortunately, without more specifics, it's difficult to diagnose accurately. However, I hope this gives you a few areas to look into, which may provide an answer and solution for you.
Posted on Feb 13, 2012
Ford focus 1.8 tdci MY 2003 terrible cold start
only takes one glow plug out of order to cause problems . check them for proper volatge and resistance
Mar 30, 2010 | 2003 Ford Focus
05 ford focus ghia/security code/touch screen
hi, if your radio code for example is 8156 you push the
no1 button 8 times then
no2 button 1 times then
no3 button 5 times then
no4 button 6 times then hold down the number 6 button for about 5 seconds and the radio code will store automatacly and start up. hope this helps you regards
Feb 09, 2010 | 2005 Ford Focus
During cold weather my 2003 ford focus TDCi is
needs new glow plugs not hard to do
Nov 06, 2009 | 2003 Ford Focus
I have purchased a 2004 1.8 tdci ford focus,I need a spare key!
go on ebay to by the key and then get it cut at like target or walmart...
once you get the new key...
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice this is rewrite mode
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possession,you are done. To end mode open door or insert key into ignition.
You'll need to follow the steps with no more than a 1-2 second delay between each step.. hope it works
Aug 10, 2009 | 2004 Ford Focus
Could anyone tell me the location of the oil filter on a Ford c max 2.0 tdci ghia
climb under the vehicle and start looking up is the best i can say. try looking on the passenger side
Jun 17, 2009 | 2001 Ford Focus
Focus tdci wont start
ive had the same problem with my ford focus 1.8 tdci wont start at all towed it to fords who says its the fuel pump and its ganna cost 600- 1,000 pounds hope this helps.
Feb 18, 2009 | 2000 Ford Focus
Ford Focus 2003 TDCi Not Starting!
check the diesel filter.it will be clogged,i am sure.Replace it.
Jun 28, 2008 | 2000 Ford Focus
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
