Question about Sony KDF-42WE655 Television
Popping noise, about once every 24 hours, no change in sound or picture.
The popping noise started soon after the optical block was replaced because of blue screen on the lower left side of the screen.
The TV is not as bright as when it was new ( 2004 ) and the lamp has been replaced, but did not make any difference..
No codes are left on the Red or Green Indicator lamp.
Also, the popping noise is not as loud as the first ones.
  • 1 more comment
  • jawaik Oct 25, 2008
    Answer to Questions:
    I did use a SONY Lamp, however, that lamp has since been removed and the original one put back.
    There is NO visable change to picture or audiable sound cvhanges.
    I have not cleaned the Mirror.
    I cannot tell exactly where the popping sound is comming from.
    Sometimes it takes from one to four hours before the pop sounds.
    This set has also had the " B " Board replaced, as well as the Optical Block, but not at the same time.
    Thanks,
    jawaik
    mistersoney,
    I tried your " Self Check " All Zeroes appear, NO ones.
    Thanks, jawaik
  • Any Guy
    Any Guy May 11, 2010
    A couple of questions:
    Did you use an original Sony lamp when the lamp was replaced?
    Does the pop correspond to any changes in the picture (change in brightness, picture jumping)?
    Can you tell where exactly the pop is coming from?
  • 320 Answers
OK the brightness issue may be from putting the old lamp back in. If not, I'm unsure what could be causing your loss of brightness.
In terms of the popping noise, there are many things that could cause a popping noise in the set. The one I worry most about is some kind of electrical discharge., probably related to the lamp driver or lamp ballast. I have seen the high voltage leads that run from the lamp ballast to the lamp socket turn brown and degarde to the point where the insulation falls off, make them a prime candidate to short, causing a popping sound. I would expect that to show an error code though in the form of a flashing red light. It could also be some kind of expansion noise within the cabinet. I would be interested in having you try this:
With the power off, press the following buttons on the remote control:
Display
5 (the number 5 on the keypad)
Vol - (or volume down)
Power
You must use the original remote and press the keys within 2 seconds total. Then read off any items that show a 1 to the right instead of a 0. I will wait for your response. If you found this information aswered your question, please be sure to rate the solution. Thanks!
Posted on Oct 25, 2008
  • Any Guy
    Any Guy Oct 25, 2008
    No errors indicates that it PROBABLY is not a high voltage pop you are hearing. Without actually being there to hear the pop or knowing where it came from, I'm afraid I can't tell you much more. I'm sorry you feel the best I deserved was a thanks for trying; you must understand that I am operating under the above listed restrictions. I hope that you get your problem resolved and if I can help you further, please let me know.
    Problem Solver:
  • 14 Answers
DID ANY ONE CLEAN THE MIRROR AFTER BULB WAS REPLACED EVEN THOUGH MIRROR ON INSIDE IT WILL STILL HAVE A HAZE FORM ON IT NEEDS TO BE CLEANED FROM TIME TO TIME
Posted on Oct 24, 2008
I recently purchased 4 K 22 soundboard for myself and my son and daughter.
i will put a pic here on how to connect the 2 tv-s
capture-wwsozecm2jr4f23puaylicsu-2-0.png good luck!!!
Apr 11, 2017 | Samsung Televison & Video
Dyson animal loss of suction only in base makes a popping sound and feel very warm
Hi Chris,
It's normal for your machine to become warm in use - like most Dyson vacuums, DC41 Animal will shut itself down for protection if it starts to overheat.
However, the popping sound and change in performance you've described suggest that something is blocking the machine. This is simple to resolve following our online troubleshooting checks: http://www.dyson.com/support/dc41/dc41-irspu/diagnosis-root-menu/performance-flo-area-check-dc41/flo-brushbarvid-dc41/redirect-to-performance-flo-base-dc41-checking-the-internal-hose/performance-flo-base-dc41-checking-the-internal-hose
It's also a good idea to give the filters a wash - in normal use this should be done at least once every three months, as shown in the video below. Use cold water without detergent, and allow at least 24 hours for the filters to dry completely before replacing them.
If you'd like further advice after you've given this a try, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 08, 2013 | Dyson Bagless Upright Vacuum DC41 Animal
TV LG Model 50PX1D-UC Flat Panel Television Loud Popping Noise. TV goes out. I turned on my tv the other morning and it let out a loud popping noise and the picture went out. Any suggestions...
The problem is that there is a bad capacitor inside the unit, it is either on the main panel or the power panel. The popping sound you got was due to the fact that the lead on the capacitor was bridging, therefore causing some electrical popping sound.
Run a check on the main panel and the power panel for any bad capacitor and replace it with a new one. That way, your television will be in good condition once again.
Take care and good luck
Jan 02, 2011 | LG 50PX1D 50 in. Plasma Television
85 Nissan stalling, popping noises.
mcdevito75 here, Sounds as though you have a worn or broken timeing belt, or problem with -in the ignition system of the engine. Have the shop check it out for you.
Feb 21, 2010 | 1992 Dodge Dakota
Popping Noise on 32" Advent TV
FIRST: Dont keep running it! It will be MUCH harder and/or expensive to fix once it blows completely!
You can look in the back and wait for a POP, narrowing down the component that's arcing. Then either replace the part or use HV Coil Dope to insulate the area if it's the flyback or some other "almost non-replaceable or extremely hard to replace" part.
GL!
Sep 03, 2009 | Televison & Video
I have a KDF 42WE655..while watching tv, I heard a popping sound.
If the lamp is blowing that soon, the cooling fan is not working, or is plugged with dust. I have heard some people have a filter that needs changing or cleaning. Check your manual. The cooling fan is on the optical block and not easy to get to.
Probably a job for a tech.
Aug 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Optoma DV10 projetor suddenly started made popping sound
hi,
Please Check and service the fans and the Air filters. then check again. In case the noise still comes then service the fans or replace accordingly. By complete service of projector, this will work.
Rave services
Jan 12, 2009 | Optoma MovieTime DV10 Multimedia Projector
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
Jun 10, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
RCA Rear Projection Blurry Picture/Popping Sounds
Might be a bad CRT, might be a bad focus block, I would refer you to a Repairman as it will take some experience to repair.
Jul 10, 2007 | RCA P52921 52" Rear Projection Television
RCA Guideplus Gold Television
I would guess the popping/cracking goes away when the picture is present. Sounds like a high voltage arc either withing the tube or due to a cracked component in the high voltage circuit. If it's the tube, then the question is: how old is the set and is it worth it to sink $$$ into it as opposed to putting the same into another unit. If it is a defective component, that's much easier/cheaper to repair. Again, age of the set, etc. I hope this helps; definitly a repair for a pro.
Oct 30, 2006 | RCA F32649 32" TV
Sony KDF-42WE655 Television Logo
113 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
