Question about Ouellet OFM0302 Electric Baseboard Heater
Heater will not turn on - Ouellet OFM0302 Electric Baseboard Heater
How do I fill water heater
Once the hot and cold pipes are connected to water heater, then open bathtub spout on hot side, turn water on so tank begins to fill.
After tub spout is running full stream without air, then water heater is full and it is safe to turn on the heater.
Turning on gas water heater before tank is full can damage tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Turning on electric heater before tank is full will burn out elements. Replace elements.
http://waterheatertimer.org/How-it-works.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My home heater keeps turning off. when we turn up the thermostat, we here a clicking sound for several seconds before the heater turns back on, My guess is that the problem is either the thermostat or the...
You likely have a time delay before the heater will kick on. You state when it turns off you turn it back up??? Is the set point temp changing? Why are you turning it up again?
Jul 19, 2017 | Honeywell Programmable Thermostat Heater
Water is leaking from a whole in the top of the water heater what is the cause
If water heater is leaking out of a hole, then tank is rusted out and needs to be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
First thing is protect yourself.
Tank could rupture.
Turn off power
-Electric heater: turn off circuit breaker
-Gas heater: turn knob from ON to pilot, so pilot light stays lit.
Open bathtub spout on hot side and release pressure.
Now you're save.
When you need hot water, turn heater on for 1 hour, use hot water, then turn heater off again.
You can limp along like this for a while until heater is replaced.
I buy water heaters at Lowes, Ace, Home Depot, Sears.
Look for scratch and dent.
Look for same size that you have now.
manufactured homes require heater that is made for that application.
Propane and natural gas heaters have different burner.
Always offer 10% less than asking price on any water heater.
You need teflon tape, 10" pipe wrench, new flexible water connectors, and a drip pan, and maybe insulation blanket.
Read how to install gas water heater.
To install electric water heater, open link above because some things are same for both gas and electric.
Difference with electric is there is no gas line, and you connect wires same way that they came off.
Feb 04, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Everytime i turn my heater on heater on works and blows fuse?
fuse blows. unplug heater blower motor turn ignition on, turn heater on, does fuse blow? if not need to replace heater blower motor
Feb 10, 2010 | 1995 GMC Jimmy
My tankless heater will not turn on and the remote
my rheem pronto tankless water heater will not turn on?
Sep 24, 2009 | Rheem Tankless Hot Water Heater...
How/where do I turn on the gas to start it
open shut off valve out side of heater and turn gas valve (inside of heater) to "ON"
May 17, 2009 | Hayward H Series Pool & Spa Heater 400k...
Ouellet OFM0302 Electric Baseboard Heater Logo
20 people viewed this question
Top Ouellet Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an Ouellet Heating and Cooling Expert? Answer questions, earn points and help others
