Question about Whirlpool Washing Machines
F22 error - Whirlpool Washing Machines
    Genius:
  • 1,028 Answers
If it's a front load duet sport suspect door lock
Posted on Oct 25, 2008
Whirlpool Duet wfw9400 is giving me a f22 error - door won't lock. I can't see any problem. Suggestions?
The F22 is a door lock error. When the control senses the door has not locked after six attempts F22 will be displayed.
There may be detergent on the door lock mechanism keeping it from locking. I recommend cleaning the moving parts of the door lock. Also make sure the wiring connections from the CCU (Central Control Unit) to the door lock are tight and in good condition.
If you have a volt/ohm meter and are comfortable working around live electricity I can give you a few checks that will help you diagnose the problem. I have included a wiring diagram that will help you locate theses connectors (see below). I have also included detailed testing information to help with your diagnosing. Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts.
  • Check VAC (Voltage Alternating Current) at IF2.
    • You should have 120VAC, if not check the wiring.
  • Check VAC at DS2.
    • You should have 120VAC, if not check the wiring and if good replace the CCU.
  • Check VAC at DLS2.
    • You should have 120VAC, if not check the wiring and if good replace the door lock assembly.
Aug 23, 2012 | Whirlpool GHW9400 Front Load Washer
Whirlpool Duet Washer F22 Error Code Follow-up
1) F22 mean DOOR LOCK ERROR , this problem can be a) switch for open or defective b) loose wires or broken wires, test by continuity VOM .
2) adjust the Door vs switch very well for propely closed, and test the closed switch.
3) see if the color are missing and put in the WRON terminal.
God bless you
Jun 28, 2012 | Washing Machines
Maytag front load washer, MHW 3000 series, f22 error message
This is a problem with the door not locking shut. Maytag have an ecellent technical assistance page on this problem with diagrams and stuff. Go to:
http://maytag.custhelp.com/app/answers/detail/a_id/2889/~/display-shows-f22-or-fdl---front-load-washer
and take a look
Jun 30, 2011 | Maytag Washing Machines
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does an f22 error message on my Maytag 3000 series washer mean?
F22 is door lock error. This is usually fixed replacing the door lock. Connection from door lock to CCU (control panel) may also be responsible.
Nov 01, 2010 | Washing Machines
Close door, f22 message, won't start
"F22" is a door latch error. The following link explains:
http://www.fixya.com/support/r1976388-f22_error_code_whirlpool_duet_kenmore
Read through all the steps listed and let me know if you still require assistance. I hope this helps you.
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 code appears on Kenmore Elite Front Load washing-?
communication error between control board and panel. Make sure both are replaced together. common problem
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
122 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
