Question about Samsung HW-C700
Samsung hwc770 goes into protection mode
Hi you turn the unit on and after 30 seconds it goes to protect mode.
SOURCE: PROTECTION
See my post "HT-DB120 - PROTECTION due to shorted output stage "
Posted on Feb 09, 2007
  • 56 Answers
SOURCE: dvd turns off after displaying ''protection''
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation or replace the fan
Posted on Jul 02, 2009
chipsandnuts
  • 70 Answers
SOURCE: Hello Protection Samsung HT-DS900
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Posted on Jul 03, 2009
SOURCE: Samsung Home Theatre "Protection Error"
i've had a similar problem where the fan stopped moving and the system gave the usual "protect" error. i think the IC's burned out on the amp board since the error was no longer there when i unplugged it. i ordered a new board off ebey for $25 shipped. make sure this is the problem by unplugging both the power and data cables from the amp circuit (the board with the big heatsink) and starting it. if it says starts normally then the problem is the amp circuit
Posted on Sep 14, 2009
  • 18 Answers
SOURCE: After 20-30 minutes work in the USB or AUX mode,
  • make sure the speakers are plugged in correctly
  • if you tried that already check if your system gets hot when it turns off
  • maybe you need more ventalation on your system...
Posted on Jan 17, 2010
DENON UD-M30 CD Player is displaying the word PROTECT and will not function. Any ideas how to fix this problem? Many thanks.
HI:
Usually when a receiver goes into protect mode, there are several reasons, One is there is a bad speaker connected to the unit, this will cause the unit to to into protect mode, try disconnecting all speaker from the unit and turning it on if it does not go into protect then one of the speakers are bad. Another reason is the power output Amplifier IC is shorted inside the unit. Another reasons could be that speaker wires are touching each other and causing a short. Disconnect all unit connecting to the unit and try turning on, if it stays on and no protect then connect them including the speakers one at time until you determine which is causing the error. If it goes into protect with nothing but the unit on then the Output IC is bad and the unit needs servicing.
Mar 10, 2011 | Denon CDR-M30 CD Recorder
It is on protected mode when i hit the reset button
Hi.
The unit goes on protected mode when an internal fault is detected.
Try disconnecting the battery cable for five minutes . If there is no fault you will clear protected mode.
If the unit still goes on protect, then check the wiring at the back, a short in there can trigger protectedd mode. If that does not work, then there is an internal fault. In that case the unit must be disassembled and tested.
Regards.
Mar 23, 2010 | Kenwood KDC-X492 Car CD/ MP3 Player
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
When i switch on my samsung HT-Z110 the word hello appears then protect thenit turned off!
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Nov 29, 2009 | Samsung HT-DB600 System
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Dec 23, 2008 | Samsung HTZ-510 Theater System
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Aug 28, 2008 | Sony STR-DE445 Receiver
Protect mode
Hi ,
Does your unit go into protect mode without speakers connected?.
Jango
Feb 08, 2008 | JVC HX-D7 Shelf System
Need help
'Protected' usually appears on amps or combined cd/amp units when the main processor detects a short circuit in the speaker connections and the unit goes into 'protect' mode to stop further damage.Check the speaker connections. You may then need to reset the unit by holding the power switch in for a few seconds while powering on the mains cord for example. Sony A/V amps are notorious for this issue.
Jan 06, 2008 | Audio Players & Recorders
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Samsung HW-C700 Logo
107 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
