Question about Delta Drills
Guardian floor model drill press parts
Model fdm-58-12s
SOURCE: I have a Buffalo No. 15 floor model drill press
http://owwm.com/mfgIndex/pubdetail.aspx?id=1268
There are other manuals/parts lists for that press on the same site.
Good luck with the restoration!
Posted on Jun 27, 2009
protek480
  • 1723 Answers
SOURCE: caN'T REMOVE A 1/2'' CHUCK FROM A 13'' FLOOR MODEL CRAFTSMAN DRILL
Try heating it up with a torch and tapping it off with a punch
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 24, 2009
Editor925
  • 285 Answers
SOURCE: ryobi spare parts
Unless you have the part in hand, which you could take to a specialized machinery or spring supplier to see if they could match it up, the only other way to get the correct part is to contact ryobi direct and talk to their parts department. They will be able to tell you the part number, and if available, send you one out direct from their warehouses.
Good Luck!
Posted on Sep 04, 2009
Testimonial: "Thank you very much for taking time to help! I have phoned Bunnings who I think are now the only suppliers of Ryobi in AU who are sending a spare. "
SRF518
  • 232 Answers
SOURCE: Hi I'm looking for a part for a drill press
check out this url:
www.jalopyjournal.com/forum/showthread.php?t=237685
Posted on Oct 20, 2009
  • 760 Answers
SOURCE: I have a Guardian Power floor model drill press.
Can you move the spindle up and down with the handle? If you can't make sure the spindle lock is not on. Is the spindle clean and rust free , well lubed? Here is a link to a manual for your drill press: http://www.dewaltservicenet.com/Products/ProductManual.aspx?q=15-331 You can order parts here. Usually the return spring can be adjusted with a nut on the left side of press. Possilby the return spring could be broken.
Posted on Jul 12, 2010
Guardian Power Drill Press BDM-58-12S Manual
Try Googling (Guardian)(BDM-58-12S)(manual) without parens.
Apr 05, 2018 | Drills
How do I change the bearings in my drill press
remove spindle and take to bearing distributor they will match it and press a new one on or just try to order the parts from manufacturer
Jun 08, 2014 | Grizzly 12 Speed Heavy-Duty 14" Floor...
I need the owners manual for Guardian Power drill press Model# FDM-58-16S
Hello, Call Guardian at 1-877-934-3585. For help with obtaining a manual.
May 15, 2014 | Drills
I have a guardian power floor model drill press model FDM 58 12SP where can I find a 5/8 chuck
in perth i would try ron mac machinery sales.. in other states also machinery sales for trades or companies in steel work.. pete
May 11, 2014 | Drills
I have an old Guardian Power drill press and I broke the handle. Does anyone know where I can find parts for it? Model #BDM58-5S
Jet JDP 12 Parts List and Diagram 707300 eReplacementParts com
This site has parts for several brands of drill presses, so you may be able to match up the part that you need. The page I tagged is for reference . You'll have to search the site for a part that possibly works for you. Hope this helpful. There are other sites that have parts, but I did not find the Guardian.
Dec 01, 2013 | Drills
I have an old Guardian Power floor model drill press and do not know how to change belt positions to change speed. help please.
See the picture below. The small red circle shows the locking screw on the right side of the drill. There is another locking screw on the left side of the drill. Loosen them both a half turn. The larger red oval is the handle to pull the motor closer to the spindle, thereby loosening the belt. Once loosened, it is easy to move the belt. Then use the handle to push the motor back, which tightens the belt. Keep pushing on that handle with your right hand while you tighten the locking screw on the left side of the drill with your left hand. Once you have that tight then tighten the right side locking screw.
Good luck! I hope this helps.
Jul 12, 2012 | Drills
I have a Guardian Power floor model drill press. The spindle will not retract. I would appreciate knowing how to fix this and where I can get parts. Thank you. Bill Powell
Jul 12, 2010 | Delta 15 331 15" 115/230V Variable Speed...
I need the owners manual for a Guardian Power drill press Model# FDM-58-16S........Help...................
I'm looking for a Owner's Manual for a 16 speed, 1/2 hp, Heavy duty Guardian Power drill press.
Apr 17, 2010 | Drills
check out this url:
Oct 20, 2009 | Drills
Open Questions:
How fix Delta/Rockwell 15 drill press from chuck wobbling. I purchased a Delta / Rockwell 15 drill press model 15-091. The chuck wobbles. I ordered some wedges to remove chuck.jacobs #6 wedges After soaking in pb blaster I removed chuck with ease with the wedges. must have Now after looking at what is called the spindle I believe...it is wobbling. I wonder if I am looking at an arbor or the spindle? Above this piece is a threaded section that is about 1/2. I thought of maybe getting a jacobs 34-33c chuck to screw onto this. Seems like if the spindle/arbor is wobbling it still would not run straight or be difficult to properly seat it. I do know that some quills come with a slot to fit a wedge for removing the arbor. Mine does not have this. Without a proper way to remove an arbor it leads me to believe maybe it doesn't have an arbor. Seems that I am looking at the actual spindle. I need this drill press for precision work. If you know about this model.. Please Help !!!!! I am stuck. Do I need to buy a whole spindle? If it is in fact an arbor how are you supposed to remove it? I thought if it is an arbor I could take a grinder and cut 2 slots in the arbor. Then take a really thick washer and cut out a section. to make it a u shape then slide the washer into the grooves I cut out. Then use the wedges on top of that. After tapping the wedges I would think it would come free. Unless it is one solid rod with a taper at the end like an arbor usually has AKA the spindle....HELP!!!! I can't find ANY info on this anywhere. I know someone must have worked on these before.
May 05, 2016 | Delta Drills
Drills Logo
252 people viewed this question
Top Delta Drills Experts
DocZachary
DocZachary
Bill Boyd
Are you a Delta Drill Expert? Answer questions, earn points and help others
