Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
I have a used wurlitzer omt how do i find out the age of this machine
My wurlitzer omt is for 45s. I want to find out the age of the machine. And I also want to see how to replace the left top bulb which seems to have gone out. thanks so much.
  • Wurlitzer Expert
  • 567 Answers
For the age of it go to jukeboxworld every one is listed
Posted on Jun 12, 2015
    Champion:
  • Wurlitzer Expert
  • 211 Answers
How do you know it is the top left bulb and not the top right bulb? The arch lights work as a pair. If one goes out they both go out.
Posted on Aug 31, 2012
  • 8 Answers
SOURCE: Wurlitzer omt
If it shows just 8 in the LED display then it is caused by the amplifier being distorted (set too loud) and/or fuse Si3 on the amplifier panel requiring changing.
Posted on Dec 27, 2007
SOURCE: Wurlitzer OMT CD Jukebox I have two Florescent tubes out
The tubes are standard "twist" fit, turn the tube about a quarter and it should come out. I had a couple of tubes go around a year ago, I got new ones from Ring Lighting of Leeds, you should be able to get them from one of the DIY sheds (B&Q etc)
18" (450mm) 15 watt, model number 61012 £1.60p each, I was told by a" dealer" that they are specially made for Wurlitzer and cost £5.50p each + vat. I sometimes think some dealers work on the bulls**t baffles brains theory.
Good luck, Graham
Posted on Jan 26, 2009
  • 5 Answers
SOURCE: Wurlitzer 1015 OMT Disc spins, then stops....
Spoke with "Doctor Jukebox" from Folsom, CA about a similar problem I had. You can find him on craigslist.
I did NOT have the "2222" display issue.
Root cause: The laser isn't "seeing" the CD and interprets inability to see as being the end of the track, therefore, puts the CD back into the carousel.
Solutions:
1) Clean the lens. Be careful to use an appropriate lens cleaning solution. The lens is made of plastic and may cloud up if a harsh solution is used. Use a Q-tip dipped into the cleaning solution and gently clean the lens using a side-to-side motion, not a front-to-back motion. Wait for a bit until the lens is completely dry, then try playing a CD. (note: this fixed the problem for me)
If that doesn't work...
2) Replace the laser module. It's easy to remove with a torx. Be gentle when disconnecting and reconnecting the ribbon cable and/or other connections so you don't bend the leads. Laser modules cost a few hundred dollars, so try Solution 1) above before replacing the module.
Posted on May 22, 2010
  • 98 Answers
SOURCE: IM TRYING TO COVERT MY WURLITZER 1015 OMT CD
To make the jukebox automatically switch between jukebox CDs and the IPOD source, you'll need the background music adaptor. I have these in stock, but need to know which amplifier is in your machine, as different amplifier types require different BGM units. Please email tech@wurlitzer-ohio.com
Posted on Nov 04, 2010
  • 195 Answers
SOURCE: I need to find a place to buy replacement parts
If your jukebox is ineed a Wurlitzer then you can order parts via a dealer, if the jukebox is by another manufacture then I suggest you look on the two following websites:-
www.victoryglass.com & www.happ.com for used parts www.jukeboxparts.com or in the UK at www.jukeboxparts.co.uk
Regards
Alan Hood
ami-man
UK
Posted on Feb 18, 2011
My Box Was Damaged in shipping, Where can I buy Replacement Plastics and Bubble Tubes.
If you google for "cd jukebox parts" you can find a list of suppliers of all kinds of jukeboxes. You check with a few that work for Wurlitzer and I think you can find what you need.
Mar 16, 2015 | Wurlitzer Jukebox 1015 One More Time...
I have a 1015 OMT vinyl machine that randomly develops a loud hum from time to time while playing a record. Turning off the machine for an hour makes it go away. I have ground lifted the AC power cord but...
Your problem is either in the amplifier board (I can repair these) or the cable going to the cartridge on the tone arm (I stock these). When the machine is making the humming noise, unplug the cable from the tone arm at the top left side of the amplifier...If the sound goes away, I'd suspect the cable. If the sound continues, I'd suspect the amplifier board. Please fee free to email for more assistance, tech@wurlitzer-ohio.com.
Feb 05, 2011 | Wurlitzer Jukebox 1015 One More Time...
How do you connect an ipod to a wurlitzer cd jukebox
To connect an IPOD to a Wurlitzer, you need a background music adaptor (BGM). I have these available, both new and reconditioned. Also, if your OMT is new enough, a complete kit to mount the IPOD on the front of the machine is availble also. Please email for more information, tech@wurlitzer-ohio.com.
Mar 20, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer omt K99 the cd will stop during play
I seem to be having the same problem and all signs point to the serial control board board Pt# 0046630 under the player. The symptoms with mine were randomly cutting off songs about 20 sec after song start and returning disc to carrier. It started mostly when juke was first turned on (cold) and then progressed to all the time and now display on cd board is dark only randomly coming to life then dead again. power on the sub transformer is good and when it comes to life player works well. I am sending the board to be repaired.
Feb 07, 2010 | Wurlitzer Jukebox 1015 One More Time...
Some individual running lights in my omt jukebox are blown, can they be fixed seperately or do i need to change the strip
I have the individual bulbs in stock. Or, if you prefer, you can send the strips and I can replace all the bulbs on them for you. Also, there is a possibility that the lighting controller needs repair. I can do this also. Please email me, Rod Stebelton, tech@wurlitzer-ohio.com
Dec 12, 2009 | Wurlitzer Jukebox 1015 One More Time...
Im looking for laser for model omt cd 100
You are looking for a CDM12 or CDMPro or CDM Pro2
Mar 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
It doesn't Light Up
if the problem is nor related to just one bulb as it sounds like it isnt then most likely you have a fuse blown or a defective lamp or 24v circuit. Check out www.flippers.com as they have the OMT manual in pdf format assuming you dont already have it.
Dec 08, 2007 | Wurlitzer Jukebox 1015 One More Time...
WURLITZER OMT REMOTE CONTROL HOOK UP
On the right hand side of the amp you should see a Din socket marked remote volume. If the machines own volume control is also in tact it may be plugged into this socket already. Just swap them over.
Aug 25, 2007 | Wurlitzer Wurrem 4-in1 Remote Control
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
314 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
