Question about Oster 76076-010 Hair Trimmer
Help I bought this Oster animal clipper unit used and wonder how old it is and wonder (even though it sounds loud) the blades don't seem to do any cutting. They marked A2 make in Milwaukee, U.S.A. Their history doesn't matter so much; I just want to trim my horses'manes and trim my dogs. There are a bunch of blades and everything looks very nice. The cap on the back of the trimmer is missing; so, the original owner 'duct-taped' it all together. It runs well and sounds powerful. Does anyone know what I am doing wrong. I oil the blades while they are running but when I try to cut my dog's hair nothing happens. Once or twice I was able to trim a lot of fur (like one or two swipes). I need to do the whole dog and a bit of the horses. Thanks. I'm about to buy another expensive unit and would rather fix this one.
  • 4 Answers
The blades could be dull, dirty, or too loose; or an internal part might need to be replaced.
northerntailssharpening.com might be helpful.
Posted on Nov 06, 2008
Hi I bought Oster golden A5 clippers from ebay and I am not sure if they are fixable. I tried to use them to groom my dog and the blades wont cut the only solution was to tape the blade flush to the unit,...
it's seem that your clipper blade are out of adjustment and also dull, The Lever from what you stated your Lever is worn out also. The only way I can help is to send your clipper and blades to us so we can make all the necessary adjustment, replace the worn out part and sharpen your clipper blades.
I don't know how many blade you have, but we can work some thing out to help you solve your problem. You can e-mail at ask@mannyssharpening.com
We have been in sharpening business since 1990 You can check out my rating on Yahoo.com Manny's Sharpening
Mar 22, 2011 | Oster Golden A5 2-Speed Universal Motor...
Difficulty shaving Spanish Water Dog
The biggest issue with clipping animals (except sheep which use completely different clippers) is that once you have sharpened blades, you need to go slow and keep then blades oiled and cooled. The KOOL spray by oster works great and the clippers you are using are a good reliable brand and model. When clipping my cocker/schnauzer cross, I have a 1/2 inch guard on it (have to use a 30 or 40 blade with the guards) and it takes about an hour. I stop every 10 minutes or so to let them cool down, spray and oil them.
May 30, 2010 | Oster 76076-010 Hair Trimmer
The blades seem loose and chatter. Two blade sets have gotten broken tabs. It seems as though the metal blade release isn't holding the blades down properly. If I seat a blade and then hold the release...
your blade need to be adjusted and also we need to check the hinge for spring tension, also your sockets on your blades may be worn out. e-mail askmannyssharpening@yahoo.com they can help you with this problem.
Mar 06, 2010 | Oster Golden A5 2-Speed Universal Motor...
Proffesional Oster clippers model 274-69 seems to be frozen...
First, these are very sensitive to no lubrication. They should be lubricated every use to every few uses. Put a drop or two of light machine oil (sewing machine oil is about right) directly on the cutting blades. That may fix your problem. Also, watch the blades once you getit running and make sure the teeth totally pass each other or it will pull hair -- no fun! The travel of the moving blade is generally adjustable via a large plastic screw on the side of the clipper.
Dec 05, 2009 | Oster 76076-010 Hair Trimmer
need oil internally gears etc... will fix problem (dry)
My electric dog clippers don't cut well
if the problem arrears to be with one blade on several clippers it sounds like you need to send the clipper blades for sharpening.
Aug 15, 2009 | Oster Health & Beauty
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
123 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
