Question about Gateway NV5432u Pentium DualCore T4300 21GHz 4GB 250GB DVD RW DL 156'' LEDBacklit Windows 7 Home (LXWDG02012) PC Notebook
Disable touchpad on gateway nv54 laptop
I had previously disabled my touchpad when the mouse was installed. Changed to a logitech wireless mouse (M185) and can't find an option to disable the touchpad. Searched control panel, tried uninstalling alps pointing device driver. nothing works. Very inconvenient. If I touch the pad while typing I end up wherever the touch takes me instead of where I want to be.
  • pfay159
    pfay159 Feb 14, 2012
    Nevermind, figured it out. It was embarrassingly simple.
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: touchpad
pluggung in a ps2 mouse will usually isolate the TP.
Refer to your manual or customer support at Gateway
Posted on Nov 26, 2007
  • 25 Answers
SOURCE: inoperative touchpad scroll zone
I had the same problem, but I fixed it.
Click start, type "msconfig," go to the "startup" tab, make sure that "synaptics pointing device driver" is checked. After you check the box, restart.
Posted on Dec 23, 2008
  • 899 Answers
SOURCE: I have a gateway MT3422 and when I got into the
This notebook does not have bluetooth. You can add a USB bluetooth dongle quite cheaply.
Posted on Feb 22, 2011
SOURCE: gateway 6451 disable touchpad
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
Posted on May 27, 2012
How do I disable the touchpad? I am running Vista Home Premium. There is no Function key to enable/disable the touchpad. I disabled the touchpad by going to Control Panel, Mouse, and disabling the...
have u gone to control panel - device manager - then on pull down menu's show hidden devices ; click on all the + boxes till you see touchpad ( mouse and pointing devices) right click mouse and click on disable.
i always go through device manager as all devices are in one place!!
Apr 11, 2015 | Gateway M-6827 Notebook
I can't click on anything on my home screen. Gateway N522 series. Won't tab or do anything. Helpppp!!!
Try ensuring that the touchpad hasn't been accidentally disabled (Hold down the '[fn]' key and press the F6 key on your keyboard to toggle the touchpad(mouse) to be enabled or disabled.
Have you tried using an external keyboard and mouse?
If the external keyboard and mouse work then we know it is something to do with the built in keyboard and touchpad on your laptop (likely - but not positively a hardware issue). If it does not work then we know that the issue is likely (but again not positively) software based.
Jan 20, 2015 | O4Jelectronicswarehousecom Wireless N...
Disable Dell Vostro 1540 Touchpad
Your problem could be that you don't have the driver installed.
Go to the dell site and then search for the Alps Alps TouchPad driver for Vostro 1540. Downlond and install. Restart your laptop and you should see an icon in the icon tray for the touchpad, you can click on that to disable it or use the shortcut key fn + f3.
Hope that helps.
Mar 17, 2012 | Computers & Internet
How to disable my touchpad on Dell Inspiron M5030 (only) when my Logitech external mouse is connected? Thanks.
You can find some instructions on disabling the touchpad herehttp://www.labnol.org/software/disable-touchpad-on-laptop/14052/
and this link has a piece of freeware called TouchPad Pal which allows you to disable the touchpad while you're typing (which should be the only time it gets in the way really) http://download.cnet.com/TouchpadPal/3000-2084_4-11143760.html
Hope this helps!
May 19, 2011 | Dell Inspiron M5030 Laptop
Is there a way to disable jus the side scroll bar on my gateway laptop touchpad without disabling the mouse itself? on my touchpad if my hand jus gets in front of the touchpad it scrolls and makes my...
yes. its in the control panel under mouse properties. Look for the advanced properties, theres alot of settings you can change there for the touch pad. There might be a link to the program in the start menu too.
May 15, 2011 | Gateway Keyboard/Mouse
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
Wireless Mouse on a laptop with built inTouchpad on the keyboard
No need to disable the touchpad they should both work at the same time. Have you tried both the mice on another PC?. The first mouse should have the correct software already installed but you will most probably need to install software for the microsoft mouse. I hope you have tried resetting by hitting the button on the receiver then while its flashing the button on bottom of the mouse? If all this fails do have any other USB devices you can test on laptop?......good luck
PS I hope its not the batteries
Oct 31, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse and Keyboard no longer work
Your laptop probably disables your touchpad when any USB mouse is detected. This is pretty reasonable, since your palms can easily stray over the touchpad during touch-typing. I'm not sure how to go about disabling that, but I'm 95% sure there's a way (even if it involves some command-line stuff).
Jun 06, 2009 | Micro Innovations PD7250LSR Wireless RF...
I have a Gateway Model No W6501. I want to disable the touchpad, but I cannot do so using the Control Panel settings - there does not appear to be any reference to the touchpad in there. How do I do this,...
While booting, go into your BIOS settings by pressing either the F1, F2, or F10 key. In the device settings of your BIOS is where you can disable the response of the touchpad.
Feb 22, 2009 | Gateway Computers & Internet
Jumping cursor when typing
Since you have a logitech mouse, lets just disable the touchpad. You should be able to disable the touchpad via one of these methods:
  1. Look on the top row of keys. You should have one that looks like a little mouse. If you do, hold down the "fn" key in the bottom, and press the key with the mouse on it. That *should* disable the touchpad.
  2. Go to the control panel, and find the keyboard and mouse settings. Digging through the menus, you should find a touchpad. You can disable it through there.
Steven
Sep 17, 2008 | Microsoft Windows Vista Ultimate Edition
Gateway NV5432u Pentium DualCore T4300 21GHz 4GB 250GB DVD RW DL 156'' LEDBacklit Windows 7 Home (LXWDG02012) PC Notebook Logo
339 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
