Question about Echo Garden
2 cycle Echo weed-eater is slow to start and once running it dies at idle. Only operates at near full throttle.
    Sergeant:
  • 316 Answers
Hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ``
Posted on Feb 18, 2012
jdlipscomb41
  • 157 Answers
SOURCE: I have a 32cc craftsman weed eater it will start
need to rebuild and adjust the carb
Posted on Oct 27, 2009
  • 130 Answers
SOURCE: my weed eater will not run more than 30 seconds
rebuild carb that will fix your problem
Posted on Jul 18, 2009
SOURCE: I have a Echo Weed Eater, it starts and runs, but won't rev up
Echo has a spark arrestor screen on the muffler-if this is stopped up with carbon it will give you the problem you describe-check your owners manual-it tells where this screen is located
Posted on Oct 12, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My weed eater will not idle. When I removed my
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Sep 13, 2010
  • 59 Answers
SOURCE: weed eater PE550 runs only on full throttle and
Your carberator is messed up. Buy a new carb for the unit.
Posted on Sep 23, 2010
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Why won't my FeatherLite FL-20C weed eater will not stay running when I put it in full choke. What could be wrong?
    It should run ok after warming up. After starting it, let it run for a minute or so and then try gradually opening the choke. You might try increasing the throttle setting at the same time. After the motor is hot, if you have to have the throttle setting increased in order to keep it running it means the idle setting needs to be increased, usually by turning a screw to keep the fuel valve from closing so much, or that there is a problem with the fuel flow......like a clogged jet or fuel passage in the carb.
    Jul 07, 2014 | Weed Eater Featherlite Fl20 Lawn Edgers
    Weed eater head spins on its own, no power.
    check the compression on your weedeater low compression will cause this
    Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
    Weed Eater Problems
    If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
    May 17, 2010 | Troy Garden
    Want stay running
    try ajusting carb did get better.if no rebuild carb and ajust carb again should fix your problem low needle 1 turn out and high needle 1 1/2 turns out this will get it runing and you might ajust again run full throttle to ajust high needle.let me know if this help you.ok
    Jul 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
    Echo Weed Eater bogs down.
    Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
    Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
    Weedeater won't take fuel
    You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
    Jim
    Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Garden Logo
    366 people viewed this question
    Top Echo Garden Experts
    Jim London
    Jim London
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you an Echo Garden Expert? Answer questions, earn points and help others
