Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Contents of crisper drawers are frozen
All of the contents in the crisper drawers are frozen. Tried to raise the temperature of both freezer and regrigerator a couple of degrees - but made no difference.
  • Anonymous Feb 06, 2009
    all food in bottom crisper drawer freezes, why
  • geano Mar 04, 2009
    Any solution for this problem??
May be a faulty compressor. ours went out last week, covered by 5 yr warranty though.
this might cause over-cooling and frozen water dispenser as well.
Posted on Oct 30, 2008
Hi my name is Steve,my Hotpoint RZA34 Freezer red light is staying on. Bottom two drawer contents seem to be staying frozen but top drawer contents only "half" frozen. Ice cream is soft and cold but a
Perhaps the ed light tried to indicate it could not reach the correct temperature of a reason?
The reason could be the compressor not working, the thermostat defect or even the cooling fluid is out.
Please try to find out why the red light is on and don't jump to conclusions. Must be a real defect.
Oct 15, 2014 | Refrigerators
Water dispenser frozen?
You have a resevoir inside the fridge compartment that needs to be defrosted. It is frozen.
It is usually located behind the crisper drawers.
It is a small plastic tank that is white about 6 inches or so in length and bolted on to the wall behind the crispers.
A hair dryer usually does the trick in about 10 mins.
Regards
Brian
Aug 06, 2008 | Jenn-Air JFC2089HE French Door...
Can I take the freezer door apart and wrap the water line with more insolation
No, you can't. The line goes into the mold of the machine with no access there.You have either an air leak in the dispenser area, around the ice shoot possibly, or the resevoir, which is located on the refrigerator side in the lower area behind the drawers is freezing, which is most likely the case. There are vents on the lower section for the crisper drawers. If you take out the drawers you'll find a roll of 1/4 " tubing which they call a resevoir that cools the water down. This is probably frozen,and you can insulate this, but I would raise the temperature in the fridge side or close the vents to the crisper area.
May 08, 2012 | Whirlpool ED2FHEXN Side by Side...
I'm having problems with my Adora fridge. First, the contents in the crispers started freezing. The storage tank behind the drawers seems to be frozen. Now the water won't dispense. Ice is being made...
Your model has a WR60X10132 or 10055112 Damper and Fan that regulates temperatures between the freezer and fresh food compartment. The part has been recently updated. Refrigerator air inlet cover/damper kit with fan motor. Damper and fan assembly has been updated to prevent freezing in the refrigerator.
(The manufacturer has replaced part number wr60x10132 with this item, part number WR49X10091.) (Manufacturer part number WR49X10091 is RepairClinic item number 1055112.)
BRB with photos and locations. Sea Breeeze
Jan 23, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Jun 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Frozen Veggies in Crisper Drawers and Water under Drawers
water under the crisper doors is pretty common, all you have to do is raise the front legs of the refrigerator, Refrigerators have a heater in them that keep everything from freezing, if it wasnt for the heater then it would just be a freezer, now alot of these samsungs have 2 evaps, so if you get a warm fridge, its prob. because a sensor is out or the heater is out and there is ice buildup inside the unit preventing either the fan from turning, or just blocking air flow, but for the water, just raise the front legs and there is a drain in the back that it will go into from now on
Jul 29, 2008 | Refrigerators
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Custom cool drawer excessivly cold
Check your thermostat setting it may be too cold try to set it higher. If your setting is ok then your thermostat or control is defective
Jan 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
366 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
