Question about Miele WT 2780 Front Load Washer
How do I reset miele wt 2780
I think I need to do a reset as I have not done the firt wash without the load. Now my Miele is washing but not taking the fabric conditioner. What do I do??
3 Suggested Answers
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Posted on Feb 08, 2008
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
Why is water not heating
Most washers require both hot and cold supply
Jan 06, 2017 | Miele Washing Machines
Miele washer does not power on at all
check the door switch or the mains fuse. they are both on the inside.
Feb 15, 2016 | Miele WT 2780 Front Load Washer
How do I get at the Motor on a WT 2780 Washing machine?
The most important thing you miss, is you should first diagnose what is defect. When 100% certain there is no cause for the defect other and died because of the usage and it is replaceable, you first should buy the spare part and then start the replacement. Without a manual I would not even start opening it. And when the motor costs more then half a new washing machine I would not even order one or replace one.
Please be careful when opening the machine. One mistake can cost your fingers or it even can cost a life.
Feb 09, 2015 | Miele WT 2780 Front Load Washer
Fault 55
I had the same problem twice. I removed the top cover and on the metal part in the middel you see a reset button on the right side with 2 connectors. Push the button in the and it will work again.
Jul 17, 2014 | Miele WT 2780 Front Load Washer
Why is my Miele WT945 front lader washer dryer not taking water in properly or at all?
you may try cleaning the inlet screen by removing the fill hose.then pry the ccreen out with a small screwdriver.
May 05, 2014 | Miele WT945 Front Load Washer / Dryer
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Problem
Could you please describe the problem you are having a little better?
Oct 20, 2012 | Miele WT 2780 Front Load Washer
Miele W 1918 washing machine front door seal replacement
the seal on the front door runs around 60 bucks and its quiet easy replaced takes 1/2 hour
May 27, 2008 | Miele Novotronic W1918A Front Load Washer
Miele WT 2780 Front Load Washer Logo
226 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
