Question about Bosch Drills
How do I remove the sds chuck on a bosch 11255vsr rotary hammer?
  • 2712 Answers
SOURCE: usage Problem
Yes, but you have to use an auxiliary 3 jaw chuck adapter and you do it.
Posted on Aug 27, 2008
rowdy45176
  • 2176 Answers
SOURCE: wanted a sds chuck for my spline chuck
The adaptor you need to convert your slpine to SDS-plus is Bosch part# HA1020. Hope this helps. Dave
Posted on Dec 24, 2008
comax
  • 154 Answers
SOURCE: i have a bosch rotary hammer 11245evs and it was
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
Posted on Apr 16, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: need \rnBosch Rotary Hammer Manual 11255VSR
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000001/r01003v-1.pdf
here you go!
Posted on Jan 16, 2010
rowdy45176
  • 2176 Answers
SOURCE: i have a 1-1/8 rotary
go to milwaukeetools.com and they have a locator service that can help you if not you can buy it online
Posted on Jan 13, 2011
What type of oil for bosch 11224vsr rotary hammer drill
special grease is used not oil order number 1 615 430 001 is the right grease for it
Apr 08, 2013 | Bosch SDS-plus BULLDOG Xtreme Rotary...
How do you remove selector knob on bosch 11255vsr
Rotate the selector to the 4 to 5 oclock position, or the 7-8 oclock postion, push the red button in all the way with a screw driver and pull the knob out. Certain model hammers you have to rotate to a slightly different position to remove the selector, you will have to try one, if it doesn't work try the other.
Dec 02, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
How do I insert a bit into the chuck on a bulldog xtreme hammer drill?
There is a collar that you have to pull back, it is kind of big. Be sure to rotate the bit, as you install it, sometimes tricky to engauge the last tiny 1/2 inch or so. The tool will be retained, but not engauged.
Sep 17, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
How do i change the brushes on a Bosch 11253 VSR?
Unscrew the caps, carefully remove the old brush, replace it with a new one that is exactly like the old. Replace the screw cap. Thats it.
Jun 09, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Bit will not come out of the end of the hammer drill.
If the chuck will loosen and the bit still won't come out try tapping firmly on the tip of the bit with a scrap of wood while the chuck is loose. There are a couple ball bearings in the chuck that stick sometimes.
Feb 15, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Looking for an owners manual for a 5/8 bosch rotary hammer
If you go to Boschtools.com you will find the manual you are looking for. They are all on the web site.
Jan 19, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Need \rnBosch Rotary Hammer Manual 11255VSR
here you go!
Jan 15, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Looking to add oil to rotary hammer Bosch / Bulldog
the oil seal is broken, remove front cover at the chuck end of the drill, and replace the seal,
Jul 21, 2009 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Wanted a sds chuck for my spline chuck
Dec 23, 2008 | Bosch 11248EVS Factory Reconditioned 1 -...
Drills Logo
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
Tim Venetis
Are you a Bosch Drill Expert? Answer questions, earn points and help others
