Question about LG Refrigerators
Lg lrsc26930tt er ff
Getting eR FF on led panel
BFixed
  • 104 Answers
SOURCE: Error code ER FF
The error indicates the freezer fan is not functioning properly. The fan supplies cold air to the refrigerator that is why it seems warmer.
The fan may be frozen, try unplugging it for a few hours to let it thaw. Also check to see if something may have gotten into the vent holes in the freezer that could be blocking the fan from turning.
Posted on Mar 11, 2008
SOURCE: error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Posted on Dec 24, 2008
SOURCE: LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Posted on Apr 08, 2009
  • 363 Answers
SOURCE: er ff
FF stands for freezer fan.
Posted on Jul 21, 2009
  • 6 Answers
SOURCE: The LG refrigerator ER FF fix
I had this same problem, with the thing freezing up, and this is how I solved it -- I took everything out of the fridge, I defrosted it for a few WEEKS (yes, weeks), cleaned the thing thoroughly, replaced the water filter, and fired it up again. So far, it's been two months, the thing is quiet as a grave, and running like a champ.
I think if you let ice form around the condenser fan, it will not go away easily. I tried the hair dryer trick, the "unplug it for a while" trick, but nothing worked. After a week or so I'd hear that grinding sound (which I think was the condenser fan and a huge chunk of ice doing their thing).
This refrigerator doesn't like to be opened a lot, and it doesn't like a door being left open, even a tiny bit, at all. The right door of the refrig can stay slightly open without the annoying beep happening, and the bottom freezer can also be slightly ajar and the beep won't go off. It's a trick to get everyone in the family to pay attention to this and make sure that the doors are all closed TIGHTLY, particularly the freezer door.
I called up the (not terribly helpful) LG people and they denied a systemic problem with the frig, and they also denied that cutting insulation was a good idea.
I am not sure what the truth is, but so far, so good with the lengthy defrost. Of course, if you don't have a spare frig, or you're not prepared to live out of a cooler for many days (I do think you need several days to get that massive block of ice melted) to try this fix, you may not be interested in it.
Posted on Aug 30, 2009
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The door panel says "Er FF" and now it is not cooling
Er FF - Freezer Fan Error - This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Oct 30, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Er ff on display panel.
You need to replace the freezer fan.
Oct 29, 2009 | LG LRFD25850 French Door Refrigerator
Error code ER FF
code for defective freezer fan motor. ER FF
Sep 21, 2009 | LG LFX25960ST Stainless Steel French Door...
What does message: Er FF mean?
That means the freezer fan is blocked, you need to order a new High voltage board, the ice has built up enough from not defrosting that it is interfering with the operation of the evaporator fan.
Jun 22, 2009 | Refrigerators
Hi, On my LG LRFD25850ST I am getting an error
er-ff is freezer fan error not running,check for ice build up around fan,a know issue.if ice build up a new main board will be needed.or just a bad fan..
Jun 20, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
FF error code
The ER-FF problem that you have is: ERROR -FAN FREEZER so it means that you have a problem with maybe the fan motor or if it's a bottom mount freezer maybe ice built up on the fan motor so it's blockin the fan motor.
Hope i helped u a little bit ! :)
Francois Pelosse
Jan 19, 2009 | Freezers
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
50 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
