Question about Garden
Missing fuel vent line
Took saw to repair shop.They never fixed it.Picked it up and fuel vent line dissappeared.Found discontinued parts used on line.Not sure how to install. Thank you
dennisgladx
  • 52 Answers
SOURCE: poulan saw
Hi joecamp1,
My name is Dennis and I'll try to be of assistance.
1) There is a primer line kit that is of smaller diameter and it goes from the primer bulb to the tank and terminates at the fuel pick-up assembly. There is also another smaller diameter line that goes from the primer bulb to the carburetor.
2) There is also a fuel line kit that is of larger line diameter that goes from the carburetor to the fuel tank.
That's a total of three lines Tank to bulb and bulb to carburetor two lines four places to connect. and tank to carburetor that is the third line and the remaining places to connect the second place at the tank and tha last at the carburetor.
Glad to be of assistance. Please rate the solution because I can learn from your rating.
Thank you
Dennis
Posted on Nov 09, 2008
dontbother10
  • 2220 Answers
SOURCE: I lent my saw out and it came back with the fuel
A typical fuel system and a couple of tips:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
IPL courtesy of "gridserver.com" (may not be your saw) You can download an Operators Manual at Jonsered.com but no IPLs.
http://s30387.gridserver.com/partsDiagrams/Jonsered%202041%202045%202050.pdf
Husqvarna is the parent company. I would try a local Husky dealer for parts if JRed dealer close. It often saves shipping cost.
HTH
Lou
Posted on Feb 07, 2010
  • 4088 Answers
SOURCE: Have a Mac 3214, fuel lines were rotten, replaced
The fuel metering needle in the lower carburetor chamber may have a bad rubber tip or the rubber diaphragm may be hard or cracked. McCullough fuel tanks vent through the cap (it should not have a gasket). Gravity plays no part in the carburetor fuel volume. Remove the spark plug (ignition off) and pull the engine through a few times without the choke on, but the throttle wide open to remove excess fuel in the crankcase (no smoking during this procedure). Make sure the plug is dry when you put it back. Hope this helps!
Posted on Apr 19, 2010
geemarie
  • 876 Answers
SOURCE: MS290 have fuel spraying
The engine is getting pressure someplace. It could be a cracked head.(This would mean the saw is a goner!) I would look at the dealer invoice and see what their warranty time is on their work and explain to him, that he did work that did not fix the problem! There is always the chance that he has a used chainsaw that he would be willing to trade for the money you have already spent!
Posted on Dec 16, 2010
philwalker78
  • 608 Answers
SOURCE: missing 025 Stihl chainsaw part
Hi, you are correct it is the tank vent. Go to a stihl shop and purchase a new one, regards Phil.
Posted on Jun 04, 2012
2001 Suzuki GSX 750 F (Katana) carburetors not getting fuel
Hi, Larae always check the fuel flow origin first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Fuel valve not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing.
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn.
7. Fuel line from the fuel valve to the carburetor or fuel pump clogged, cracked, pinched, bent, broken, or missing.
8. Fuel pump not working.
9. Fuel line touching cylinder or head causing fuel to boil and vapor lock, repair by rerouting and wrapping line with convoluted tubing.
10. Carburetor inlet clogged.
11. Carburetor float or needle and seat stuck.
12. Carburetor not venting properly overflow line or bowl fitting clogged, pinched, or bent.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
ISSUE engine not getting fuel Suzuki GSX Motorcycle Forums Gixxer com
Fuel supply valve on Suzuki GSX750F Katana
Suzuki 85 GSX R750 Service Repair Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 30, 2017 | 2001 Suzuki GSX 750 F (Katana)
Missing 025 Stihl chainsaw part
Jun 03, 2012 | Stihl Garden
MS290 have fuel spraying out of vent and fuel cap. took to dealer for repair, he replased the carberator and the vent line. no problem at the store. went to work cutting fire wood, stated doing thye same...
Dec 16, 2010 | Stihl MS 290 Chain Saw include 20" 50cm...
Hi have fuel coming out of muffler and was blowing out of breather
This saw has a fuel tank vent that could be leaking a small amount of fuel, or the fuel line coming out of the tank could be leaking. Fuel line replacement isn't complicated, you could try installing a new one. If it's the vent, odds are it's not enough to cause alarm........unless the vent line is cracked. In that event, you should replace the vent hose. Again, not a complicated repair.
Nov 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have 60 inch zenith inteq projection TV no picture or sound it powers up fine took it to a repair shop tech guy said that a whole board need to be replaced but the board is a discontinued item said it...
May be you went to the wrong place, find another repair shop where they work that brand and type of tv. Doubtless, some parts are discontinued, but they will take parts of another equipment that are dismantled. Good luck.
Oct 06, 2010 | Zenith R60V26 60" Rear Projection...
Have a Mac 3214, fuel lines were rotten, replaced lines spark plug and air filter. Started saw ran fine. Shut off saw, heard a girgling sound took off carb cover had fuel filling carb above throttle blade,...
Apr 18, 2010 | McCulloch 10" Electric Pole / Chain Saw
Poulan p3416 runs for a short time....stalls and then won't start..what could be cause?
Immediately after it stalls do this:
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
If spark good:
When it begins to stall loosen fuel cap if that fixes it fuel vent problem.
If spark and vent good it is most likely a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor.
Was this saw perhaps operated without oil mixed with the fuel?
· Remove the spark plug wire and plug.
· Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and inspect the cylinder, above the exhaust port, through the spark plug hole. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by the independent saw shop should be considered. HTH
Lou
This will even work on a Chinese McCulloch 3416. If this is a Mac it may be very difficult to find a repair shop willing to repair it.
Oct 11, 2009 | Poulan Garden
Heater/ac door actuator isnt workin right. air coming out of bottom and top vent but not from the face vents. keep switchin control to switch vents. only goes to bottom and to the windshield vents.
Sounds like either the computer that controls the auto climate control has gone out or you could have a vacuum leak. I would definitely check the vacuum leak first. I took my 98 Lesabre to a repair shop several years ago for the same problem. When I picked it up they told me my computer was out and it would cost around $600 to fix. As an alternative, they had unhooked and rerouoted vacuum lines, breaking a tube off the controls under the right side of the dash. They told me that they would have to remove my glove box each spring and fall and reconnect the vacuum lines to change the airflow from floor to dash and vise versa. My fix was to run the lines under the dash just beneath the ash tray and connect shut off valves to the vacuum lines. Now when I need to use the AC I can change the flow of the vacuum by simply turning these two valves so that the flow changes from floor to dash or back. I know this is pretty jack leg but the damage had been done and this has actually worked pretty good.
Aug 16, 2009 | 1997 Buick LeSabre
I have a 3516 chain saw mod22-600035-18 Mcculloch the fuel lines
I wish I could help. There are no parts available, there are no Exploded parts lists I've found a link to. These are Chinese chainsaws with the McCulloch name. They ARE Chinese chainsaws and I'm disappointed in Mac. Most mechanics won't touch them. We can provide no more help with this saw. Sorry
Lou
Poulan or Craftsman gasoline chainsaws are reasonably inexpensive, parts are available, and given a little TLC perform well.
Jun 10, 2009 | McCulloch Garden
Chainsaw kills when I press the throttle
My 372 xp did that and when I talked to the repair shop they even showed me. There is a fiberglass gasket that is used to mount the carburetor to the engine. I have no idea on how this happens, but I saw it with my own eyes. The gasket had actually folded over. They replaced it with a rubber one and have had no problem since. The saw was hard to start, would run as long as I didn't try to cut anything and when I did it would open up and then die. I could be giving wrong information, but that sounds exactly like the problem I was having.
Oct 08, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
