Question about John Deere Garden
My John Deere 425 runs and shuts off, cools down and starts up.
No spark on either cylinder.
  • John Deere Master
  • 2,239 Answers
If you have tried a new plug, it could well be a case of replacing the ignition unit,
Posted on Feb 14, 2012
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
buffalonyman
  • 1865 Answers
SOURCE: John Deere L118 / 22hp Briggs stalling when it is hot
Have you replaced the fuel filter?
Posted on Aug 08, 2009
SOURCE: john deere 425 lawn tractor. it wont start but it
My John Deere did the same thing. Turned out to be the emergency brake sensor.
Posted on Jan 21, 2010
My 1908 John Deere 425 Zrider, Shuts down when releasing parking brake.....baffled!
start check the safety switches ---seat--brake--pto /blade engagement --
Jun 08, 2017 | John Deere Garden
I have a john deere 425 20 hp OHV K series liquid cooled. After about and hour or so of run it overheats and stop. I put a new air filter on it. that didn't help.
check fluid level in the cooler / radiator that its clean 'air can flow through ' air filter is fuel and carb not cooling system --
Nov 18, 2016 | John Deere Garden
John Deere 737,Kawasaki motor, gets hot start's missing on one cylinder, cools off start's run fine, could it be the coil breaking down
possible so have the coil checked
could be from dirt and grass blocking the cooling fins of that cylinder causing the problem with mixture
if you spent that much with a dealer and the problem was not fixed maybe you should complain about the cost and the failure to fix the fault
May 13, 2016 | John Deere Garden
John Deere L120 gets hot and shuts down after mowing for short time
remove the top cover and see if there is a nest or grass build up on top of the fins or are you loosing spark when it gets hot then remove the cover and check the coil
Apr 11, 2012 | John Deere Garden
John Deere LT 133 lawn tractor quits running after about 10 minutes.
Will it restart right away or does it have to cool down? If it has to cool down, then run it until it quits. Next remove the plug, reattach the plug wire, and ground the plug to the block. Finally try to start it with the key. If you get no spark or very weak spark then the ignition coil needs to be replaced.
Let me know how it goes.
Aug 18, 2011 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
My john deere 425 wont start cranks motor spins will run a few sec with starting fluid then dies
Check your fuel filter and see if it's clogged. You might be able to blow it out with an air hose if it is.
Feb 08, 2011 | John Deere 132 425 Lawn Tractorsnow...
John Deere 425 AWS no start, no nothing???
Sounds more like a bad starter than a bad coil.
A failing coil usually shows up during hot weather. The engine will start and run fine, then when it heats up, it just dies out. After a few minutes, it cranks again. Then the cycle repeats itself.
The ignition module and coil pack are the same part.
Are you sure full voltage is getting to the starter? There is likely a starter solenoid between the ignition key and the starter. These solenoids can be problematic and prevent the full 12 volts from getting to the battery.
Oct 16, 2009 | Garden
After the mower gets hot, it shuts down.
my john deere did the same thing i had spark and it did run,but the coil heated up an there was a short in it and it would stop and you wait awhile and it cool down and it would start again,i replaced the coil and the problem was gone.
Sep 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
614 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
