Question about RCA Televison & Video
How to hook-up Auvio wireless headphone to tv?
Have Directv dvr that I'm trying to hook-up wireless headphones
  • 40 Answers
SOURCE: Motorola DVR headphone problem.
are you connecting the headphones to the tv or cable box. Also is there any home theater systems being used in this setup
Posted on Apr 05, 2007
  • 374 Answers
SOURCE: adding tv to a dish network dvr
Your upstairs tv is connected via a coaxial cable and you can do a few things to get programming to the third room.
The first is to locate the wire that enters the upsairs room that currently has tv and insert a splitter by cutting the line to that room and running the out ports to the rooms and the in port to the other end of the wire that you cut. This will give you the same picture in both rooms.
If you have a system that does not use diplexers to backfeed the second TV you can backfeed the 3-4 cable going to the TV1 by cutting the line and adding a splitter with the inport running to the 3-4 port on the receiver and one of the out ports going to your tv1 and the other outport going into the UHF side of a diplexer. You will need to cut the Satellite feed into the back of the receiver on the back side of the seperator and connect the seperator to the SAT port of the diplexer. The IN/OUT port of the diplexer will connect to the end of the sat feed cable that goes to the wall plate. This will allow you to go into the attic of outside of the house and find the sat cable that feeds the TV one and break it there and put the IN/OUT port of that diplexer facing the TV1 room and the SAT port connecting to the other end of the cable you broke. The remaining UHF port will be the feed for the new room that you wish to connect. This set up will allow for viewing the same program as that at the TV1 location however you will need to change the channels at the TV1 location or buy an IR to UHF converter to allow you to be able to work the system independently from the receiver. Hope this answered your question. IF you need further assistance please contact me and thanks for using Fix Ya.
Posted on Dec 31, 2008
b_stro804
  • 68 Answers
SOURCE: how to i hook-up a directv dvr plus to two tv's?
plug one tv using coax (screw in cable). plug the other using composite video cables( yellow, red, white). It will be easy to connect the tv that's the farthest with coax, its cheaper to purchase 50ft of coax vs 50ft of composite video.
Posted on Jan 04, 2009
SOURCE: Headphones socket does not work
What a con. There was no mention of paying for this advice when posting the problem. I'd rather pay a TV shop to look at the problem. Thanks for nothing.
Posted on Jan 10, 2009
  • 71 Answers
SOURCE: Directv to Dish
Can Not Be Done. Dish and Directv use different encoding software.
Posted on Mar 15, 2009
Where do you install the battery's for Auvio wireless headphones 3301089
The decorative cover on the left phone will come off. It is meant to come off. It snaps back on. Start with a very sharp knife and work your way up to a screw driver and then pry away.
Aug 05, 2016 | AUVIO Stereo Wireless Headphones
Trying to get hook up with AUVIO wireless headphones to SONY TV MODEL KDL-40W600B. If not AUVIO then my Beats pill. Goal to have TV sound in/on bed close to me. Beats pill Blootooth
Jean,
I take it the Auvio wireless headphone main base has both dual rca and optical in jacks? If so, what you need is a 3.5mm stereo male to 2 rca male cable. You will plug in the 3.5mm male plug into the green audio out/headphone jack port that should be on the back/left rear side of your TV. Then you will plug the dual rca plugs of the cable into the Auvio rca inputs. You can get the cables in various lengths so you can have the Auvio base in a good location. If you need a visual of the cable type: http://www.monoprice.com/product?c_id=102&cp_id=10218&cs_id=1021815&p_id=5598&seq=1&format=2
Hope this helps:)
Sep 13, 2015 | Sony Televison & Video
I bought an Auvio wireless headphones for my dad his RCA flat is giving me problems to make they work If I do conectadod them to the headset device they work but the TV does not sound just the headli
The tv might not have a audio input driver installed. This happened to me it might say "not supported". When the driver is installed then the headphones can communicate with the tv. If there is no driver then they can not communicate.
Jan 11, 2015 | AUVIO Stereo Wireless Headphones
Can I connect to Vizio TV with blue tooth
If your ear buds have been connected to any device before your TV then it won't work. If you want to connect it to your TV you turn on your headphones, hold the call button for 3 seconds, and you will see ur light flash and connect it to your TV. If this didn't help then go to the manual and check how to connect your headphones to your TV.
May 24, 2014 | AUVIO Bluetooth Headphones
Won't connect to bluetooth
Well you have to hold the call button for three seconds and the it will flash and now your phone will find the headphones and it will be successful connecting.
Mar 27, 2014 | AUVIO Bluetooth Headphones
Red light wont turn off on auvio headset
While your headphones are charging press and hold the call button and volume up button and your problem is solved.
Mar 22, 2014 | AUVIO Bluetooth Headphones
Televison & Video Logo
196 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
