Question about Toshiba Satellite 5005-S504 Notebook
Can't recover I have a Toshiba 5005-S504, when I start up and hit F12 to choose boot order, I can choose the cd (xp pro cd in drive) it just starts up windows normally. Any ideas?
  • johnbob71 Oct 25, 2008
    I was told that F12 chooses the boot order, I would like it to boot from cd to recover, but I get nothing when I choose the cd icon. Toshiba had told me F2 but that doesn't do anything either
  • Frank
    Frank May 11, 2010
    why are you hitting F12 when it start??
    Genius:
  • 1,124 Answers
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Posted on Oct 25, 2008
How to change boot order to usb in emc utl laptops
Easy wen you turn on the lap pushh many times type F12 wen the promt apear and then it give to you the wayfrom to start chose the usb from or other is go to bios sistem and in the loader change it way from to star from hdd to usb hdd and ready post please if this is work
Feb 05, 2014 | Toshiba Satellite 5005-S504 Notebook
How to remove cd drive Toshiba 5005-S504 laptop
If you remove the memory card cover, there is a screw under it that holds the DVD drive in. Remove the screw and the drive will slide out.
Hope this helps.
Nov 16, 2010 | Toshiba Satellite 5005-S504 Notebook
How can i install windows xp in to my toshiba satellite using a usb cd drive?
you can copy the contents of the windows XP installation disc to the USB drive. A 1gb flash drive should be sufficient.
Apr 11, 2010 | Toshiba Satellite 5005-S504 Notebook
MY CD DRIVE NOT READING ANYMORE. THE OS GOT CORRUPTED AND NOT LOADING IN ANY MODE EVEN IN COMMAND PROMPT. I WANT TO INSTALL OS BUT CD DRIVE NOT READING. CAN I BOOT FROM EXTERNAL CD DRIVE. IF SO, HOW? HELP
If you can get into the BIOS, go to boot options and make sure that the usb boot option is enabled and then make the usb the first boot option. hit F10 to save and exit. Load your OS disc in the external drive and reboot the machine.
Oct 08, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba 5005-S504 recovery problem
Unfortunately , you are going to have to call Toshiba.
from the sound of it your recovery disks are failing and they have already formatted your harddrve
May 09, 2009 | Toshiba Satellite 5005-S504 Notebook
Changing BIOS priority on toshiba satelite 5005-s504
as i recall, ntloader is software for the OS load, after hardware boot, so you already passed up your chance to enter bios, which you realize. i used to have a toshiba laptop, was it the delete key or F2 to enter BIOS? try delete, and make sure youre pressing it from restart like once a second as it's booting to make sure you hit it in the windows of time it's looking for key presses before it's time to load the operating system. you'll be fine. it's just unnerving to be locked out like that...
Feb 01, 2009 | Toshiba Satellite 5005-S504 Notebook
I just bought a toshiba satellite 5005-s504 on ebay it was shipped to me and all programming has been deleted I need to reload windows xp how do I do this I have a disc for windows xp but the laptop will...
When the computer starts to boot up does it ask you to boot to CD/DVD?
1. If so put the xp disc in the drive and turn on the power when it asks you to boot to CD/DVD press any key. This will start the installation process.
2. If it does not ask you to boot to CD/DVD you will have to go into Bios and change the boot priority to boot to disk drive first. save the settings and do the first step over again
Jan 31, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite pro m70 screen problem
try to connected it to a external monitor. and hit the "screen" (square box).
Aug 15, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504; boot from USB? Reformat HD w/o CD-ROM?
First these laptops are what is called "Legacy Free", meaning there is no BIOS, at all, ever, for all time, not gonna be there.
Second, the Floppy option is referring to any supported USB Floppy drive. If you have one great, if not this will be more difficult.
NOTE**** - If at any point you do not know what I'm referring to, please do not attempt this, you will likely render your HDD useless.
If you have the Floppy on USB, then you will need the XP setup on Floppy Disk and there are alot of disks, and from my own experience so far, No, a USB flash drive will not work, I even tried an emulator which formatted it as a floppy disk.
If you do not have a floppy, then you will need to remove the harddrive and connect it via an external USB drive cage to another pc, create two partitions, one for your OEM OS disc, the other for the installation. Obviously your OEM OS Disc is not all that large, only partition what it needs, and make sure you make it a bootable partition. For XP you will also need the SATA drivers for the hard drive as XP does not have them included in the setup disc. If you do not have these, you will need to find them or just stop here, because you can go no further.
This is one of the biggest drawbacks of a "Legacy Free" system, you cannot change the SATA operation in BIOS like most other pc's. The system configuration is done through a windows utility from Toshiba.
Oct 14, 2007 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
203 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
