Question about Garden
John deere sst18 what pattern do you put the blades back on
I can not remember how the blades go back on after i took them off after i got wire wraped round the centre blade
5 Suggested Answers
  • 18 Answers
SOURCE: blades will not ingage
is it electronic engage or manually?
Posted on Sep 03, 2008
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
  • 218 Answers
SOURCE: blade position for 155c john deere
Hi..my name is Keith...to answer your question..there is no certain position to put the blades and there is enough clearance that they wont hit...but there is a proper torque on the nut when reinstalling the blade..and its usually like 100 foot pounds..i hope this has helped
Posted on Jun 30, 2009
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Posted on Oct 22, 2009
Wiring diagram for a john deere sst18 lawn tractor
Russell if you truly want to figure out this problem you need to look at the wires and ware they connect .And what they connect to then drew your own wiring diagram its not that difficult if you break down and do a few tests with an OHM meter to see what is connected and what happens when you through a switch or run a jumper wire to a ground .
If you think about its not really that complex .
Jun 08, 2016 | John Starter Deere Sst18 Spin Steer Deere...
How to change cutting blades on john deere Z710A mower?
you should be able to life the deck to its highest possible setting, and get a wrench to remove the blades, you'll need 27" blades. the shaft may have a star pattern as well as the blades. when you replace them, you want to make sure you remember what direction the blades were sitting when you removed them and put them back in the same way, so you dont have blade interference
Jul 17, 2014 | John Deere Garden
My zero turn mower will not steer and the blades will not turn The only numbers i can find are MOSS 18C010041 SST18 W/48C
on the inside underneath the mower by the handles there is a bolt , this bolt allows you to push the mower when it is not running, so take brake off and see if you can push the mower if you can then the bolts need tighten. The blades are engaged by the PTO..... wait a minute sounds like you have a belt problem. check the belts make sure they are on all the pulleys. Hope This helps Tim
Oct 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Jun 07, 2009 | Garden
Apr 18, 2009 | Garden
Blade position for 155c john deere
Apr 11, 2009 | Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
