Question about Garden
Won't start Won't start...it sounds like its not getting gas. Had carb cleaned and new spark plug...still nothing. It will turn over and that's all.
Fuel pump?
Posted on Feb 13, 2012
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
2006 kawasaki 250 ninja has spark, gas to the carb bowls but won't start
If plugs are dry then blocked idle jets are the most likely problem...
Sep 22, 2012 | kawasaki Ninja 250 R Motorcycles
Craftsman 2400psi 6.0hp briggs & stratton pressure washer won't start
try and start it with starting fluid if so rebuild the carb
Aug 07, 2012 | Garden
2006 Honda Shadow won't start. Gas tank filled. Sat 8 mo. Gas leaked out but not into engine.No sign of external leak. into
1. Drain the gasoline.
2. Remove the carb bowl(s) and turn on the petcock to drain the fuel in the lines.
3. Clean out the carb bowl(s) and replace.
4. Refill with gasoline, add 1 oz of Seafoam fuel system cleaner (I'm not a sponsor, I just haven't found anything better) to each gallon of gas. This will stabilize your fuel as well as do a great job of cleaning out the carb(s).
5. Try to start it.
If it still won't start, begin the standard troubleshooting procedure by first pulling a spark plug and turning it over to ensure gas is getting to the cylinder. If so, replace the plug, hold the plug wire slightly away from the plug and turn it over to ensure a spark jumps between the wire and plug. If so, it starts getting complicated. Buy a manual for the bike if you don't have one and follow the troubleshooting steps there.
Jul 24, 2012 | 2006 Honda Shadow Spirit 750
1999 Yamaha 1200GP Wave Runner wont' start. It has sat for about 2 years. I have new battery, new plugs and new gas, it turns over but won't start, any suggestions?
Sounds like the carbs are gummed up from the old gas sitting in them. Remove the carbs, disassemble, clean with a carb cleaner, and reassemble.
May 14, 2012 | Motorcycles
I have a 1985 Yamaha maxim that hasn't been ran
Spray starter into the carb intake with no choke, if she runs for a few seconds then you know its fuel starvation
clean jets & airways & blow through with compressed air
Nov 20, 2011 | 1985 Yamaha XJ 700 S Maxim
Scooter sat for a year; wouldn't start; replaced battery. filled with gas. cleaned spark plug. won't start. Help
after a year sitting idle chances are that the gas inside the carb has degraded and the carb will need cleaning also when you filled the tank did you remove any old fuel? if not the its contaminated with the old gas
give it a full service new feul clean carb clean air filter then it should start
hope this helps
john
Jun 30, 2011 | Aprilia Scarabeo 50 Four Stroke...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
