Question about Cuisinart (ICE-20) 1.5 Quart Ice Cream Maker
Cuisinart dcc-1150 coffeemaker
The clean button is flashing,how do I clean the water filter?
  • 8,596 Answers
To replace water filter: Pull water filter holder out of reservoir, snap open, insert new charcoal water filters (can be ordered from Cuisinart or purchased froma store like william-Sonoma)
To clean machine: Run 2 cups water and 2 cups distilled white vinegar through machine like you would normal coffee.
To get rid of annoying self-clean lite: unplug machine from wall outlet for 20 minutes or longer.
-Tha Mp3 Doctor
Posted on Dec 10, 2008
I accidentally washed the cuisinart ice cream bowl in hot water. is it beyond fixing?
Hi, I always wash the bowl in hot water, would not have it any other way for hygiene reasons & have never had a problem. After all it is only made of aluminium ! What has happened to yours to make you think you have a problem ?
Peter.
Nov 03, 2010 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Instructions for coffeemaker cuisinart DC1200 need to know how to set the automatic time for cooffemaker
Turn dial to PROG
Press and release HR button a few times - it will have a "PM" on the display if it is set for PM
Press and release MIN button until minutes are set
Once the time you want it to go off is selected, turn the function knob to AUTO-ON - flick the switch to ON - a green light will now illuminate and you are ready to go (don't forget to put water in the reservoir and coffee in the filter basket)
Sep 24, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Clean light stays on,help me trouble shoot
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
If your Cuisinart is one that is missing the Self-Clean function, just brew the vinegar and water like it is coffee by using the brew function.
Sep 19, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Recently bought a used Cuisinart DGB500 and do not have a manual. I should be able to figure out the controls but believe there is supposed to be a water filter. No sign of one that I can find. Also, does...
Yes. the paper filter absorbs yhe oils and traps fine sediments. Look up how expresso machines work by typing it in the search bar. It may refresh your nenory. Good Luck
Jul 11, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Mixing arm/bowl will not turn once machine is turned on
The only thing I can really suggest is to make sure the easy-lock button is fitted into the right place on the lid, and to make sure that the ice cream mixture is not too thick. But, if the turning paddle is locked into place properly, and the mixture is still in liquid form, then there is a problem with one of several parts - could be the metal sliding switch or even a motorized part. These parts cannot be replaced. It is worth a shot to replace the mixing paddle - the unit has a 3-year warranty, so I would Call Cuisinart to get the part instead of ordering it online - they may or may not give it to you for free. If the new mixing paddle still won't spin, get the unit replaced either thorugh the store (depending on the store -each has a different policy) or get it replaced directly through Cuisinart. This model is actually pretty solid, so a second one shouldn't give you any problems.
-Tha Mp3 Doctor
Mar 05, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
How do I set the timer for my cuisinart atomatic coffee maker to start in the mornings.Lost owners manual HELP
Slide dial to PROG, then press hour and minute button - that's the best i can do without knowing the EXACT model # of your Cuisinart.
Dec 04, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Coffee taste bad
Coffee Tastes Bad- Cuisinart
1) Run 1 tsp lemon juice per 1 cup water through Cuisinart
2) Use filtered water
3) Replace the charcoal water filters every 3-4 mos
4) Use better coffee
-Tha Mp3 Doctor
Nov 12, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Cuisinart MM-2 Mini Mate Chopper/Grinder - Instructions
In order:
Yes, you must twist off base to remove blade - only twists one way, not the other
Yes, instructions online/manual:
http://www.cuisinart.com/share/man/72_man.pdf
SRP - $79.00
Current Price - about $40.00
Orig manufactured 2003, but the first # in serial # will tell you your exact manuf. year, 3 = 2003, 4 =2004 etc
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Cuisinart (ICE-20) 1.5 Quart Ice Cream Maker Logo
297 people viewed this question
Top Cuisinart Ice Cream Makers Experts
Greg Cann
Greg Cann
Jay Finke
Jay Finke
Oloyede Monsuru
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
