Tray wont open device mgr says working properly
Wont open when u right click and go to disk eject either
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Posted on Feb 17, 2012
sandrew
  • 2961 Answers
SOURCE: Drive wont open/eject
try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the notebook and then the drive will be re installed with drivers automatically. it may be a firmware or driver error.
Posted on Apr 18, 2007
  • 46 Answers
SOURCE: dvd burner won' eject dvd
On the front of the burner there is a pin hole. Take a paperclip and unfold it so it's a point. Stick it in the hole and it should open the tray. This should FixYa!
Posted on Jan 27, 2009
MPetro302
  • 298 Answers
SOURCE: my LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Posted on Apr 20, 2009
  • 81 Answers
SOURCE: DVD drawer in my Dell
check the rubber inside the DVD-ROM.
Posted on Nov 11, 2009
  • 162 Answers
SOURCE: disk drive wont open/eject computer says no cd
there should be a tiny hole in the cd drive get a paper clip and push it it will open the cd draw
Posted on Jan 03, 2011
What is the proper procedure for opening the dvd drawer on a gateway ne 522 laptop
Locking device or software installed First, verify no locking software is being loaded that prevents the tray from opening. If you are unable to determine this, reboot the computer and as it is booting up, eject the tray. If the tray is able to eject as it is booting, but stops working after loading Windows or your operating system something is being loaded that is preventing the drive tray from opening. This is most commonly software such as a CD burner program that has taken control of the drive.
Bad eject button If you are running Microsoft Windows open My computer, right-click on the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective and it is recommended that the drive be replaced.
Jan 06, 2014 | HP Computers & Internet
Lenovo Z570 Disc tray is stuck -outside of laptop
Open the try slightly, shut down the machine, tilt the machine to the side of the DVD/CD drive a gently shake to loosen the tray or whatever is causing the problem, Is the disk off the spindle? Is the dvd/cd broken? Can you insert something to clear whatever is obstructing it? Have you tried to eject using the software, Go to computer, right click DVD/CD rom drive, click on eject? Has there been any damage to that area, bent..etc? You may have to force it open or remove the drive and try to open it.
Nov 19, 2012 | Lenovo Computers & Internet
How to eject dvd disk samsung laptop no eject button?
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Apr 01, 2012 | Samsung NC10-14G Notebook
Disk drive door wont open. LED light comes on an hums, but tray wont eject to open. Where is manual eject hole located?
Below the drive tray there is a tiny hole, straighten a paper clip and gently insert the paper clip into this hole. Push the paper clip and the tray will release and pop out, then pull the tray out to the fully open position.
Mar 02, 2012 | Computers & Internet
How do I eject a disk from my dell model 1737 studio lap top(window vista) . It made noise are clicking sound when it went in.
Hello Reg,
The CD/DVD rom is tray type then use a pin to eject the tray. There is small hole in front of tray plate.
Insert the pin in the small home and press smoothly and the tray will eject .
If the CD/DVD rom is different type then use long steel V shape clip to pull the disc.
Apr 14, 2011 | Dell Studio 15 Laptop
I inadvertently left a copyright CD in E drive. Now cannot open the CD tray to take out the CD. Dell computer. What to do?
In case the eject button on the tray don't help try to open "my computer", right click on the proper cd/dvd tray and choose eject. In case that didn't help you have to locate a small hole on the tray near the eject button. Use a paper clip and through this hole push the internal cogwheel to rotate and open the tray. Take care that it's not always due to the disk that the tray can't open; maybe it's a cd rom's mechanical problem and will lock again a cd or dvd disk.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 05, 2010 | Computers & Internet
Using the jump drive device
no it shouldn't crash. you can just pull it out but i guess the "proper" way is to go to MyPC right click it and click eject
Feb 25, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Intel iMac: disk does not eject, does not mount, makes no noise
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here are some steps I recommend you try to resolve the issue with the disc not ejecting properly. Now you mentioned that you used the drutil tray open command- if that is correct, then for your Mac Mini, that will not work, because that command is for drives with trays only.
In your case, you have slot drive in your Mac Mini so try the command line that I have provided below. It is just a slight modification from what you stated you tried.
-EJECTING DISC USING TERMINAL-
From your Desktop:
•Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
• Locate and open the Terminal application.
• At prompt, type: drutil eject and press the Return key on your keyboard
(NOTE: If you have a CD/DVD drive with a tray, type: drutil tray open press the Return key on your keyboard).
If that procedure with Terminal does not work, there are two applications that you can try:
Disk Utility- You open the application, select the affected disc or the optical drive in the left sidebar window. Then select eject from the top of the Disk Utility menu. See if that work.
iTunes- Simply open the application, and select the eject icon at the bottom of the window.
Last but not least, I did notice you did not mention that you try this procedure:
Reboot your Mac Mini.
As the Mac Mini boots up, hold down all mouse buttons and keep holding them down until (hopefully) the cd ejects.
I am not sure if you have done all of these processes for ejecting your disc, but again these steps were not mentioned in your initial inquiry.
Let me know if these additional steps have helped or if they are in fact redundant.
Regards,
-Mactechtrainer
Feb 02, 2010 | Apple Mac mini
My Acer Extensa 5620Z DVD-ROM Driver wont open or operate
#1
first go to your system tray and click on the "Safely Remove Hardware" icon
** if it's not there you can skip this step
click on the icon and stop your dvd/cd drive
#2
There is an eject button on the side of your drive. not the disk eject button. this button will eject your drive from the computer. it should be on the right side of the drive. push this button and remove your drive.
#3
Inspect the drive for signs of damage.
Give it a few blows of air to knock any dust off it
#4
Reinsert the drive into your computer
After you do that Windows should recognize there is a drive there and little bubbles should pop up from your system tray. give it a minute to finish.
#5
Insert a disk and check to see if it is working properly
IF windows didnt recognize it and/or it still has no power, you most likely will have to replace your drive. but let me know what happened after you do this
Dec 26, 2008 | Acer Aspire 5100 Notebook
DVD-Rom drive doesn't work.
right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
May 17, 2008 | Maxtor Hard Drive
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
