Question about Toshiba SD-3980 DVD Player
Completely dead About a year old used very litte no previous problems: tried to use it and nothing happened. No display, with remote nor power switch on unit. Fuse has continuity.?? If I buy a new one: should a $100 one out last the $30 one? I don't need anything fancy.
  • Anonymous Sep 17, 2008
    SD-3980 is completely dead. Where can I obtain the schematic and service manual?
    Dave Gundling
  • David Gundling Sep 17, 2008
    My SD-3980 is completely dead. fuse is good and power is getting in. Can anyone tell me how to obtain the service manual and schematic?
    Thanks.
    dgun
Check the electrolytic capacitors on the power supply board. C827 (470 uF, 16V) on mine was shorted, thereby killing off the +12V supply. Once I replaced it the player worked fine again.
Posted on Oct 09, 2008
I suggest u the better model ,panasonic dvd player s33,and new all pioneer models,this model very cheap and have all feutures.because iam working panasonic auth service centre in kuwait. i am using the player s 33 last 2 year.
Posted on Aug 28, 2008
Please Ur service center address in chennai
Posted on Apr 23, 2008
  • 50 Answers
Hi This is my opinion only, but I have worked on many many DVD players, and if you don't need anything fancy, then go for the $30.00 unit. Actually, I would look for something in the $50.00 range, as the $30.00 units are very cheaply made. I have often worked on a $100.00 unit, followed by a $50.00 unit, which had the exact same laser and mechanism inside, the only difference being the brand name stamped on the front. But.... You could purchase three $30.00 units, for $100.00 and if you used them one at a time until the last one died, I dare say they would very likely outlast the $100.00 unit by far. I've probably just confused you now, so I'll just end by saying that on a regular t.v., the picture will look just as good using either option, and you can have good luck or bad luck with any piece of electronics expensive or not. Good Luck!
Posted on Aug 16, 2006
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
When I use the remote to turn the television on, nothing happens.
This problems happen to all LCD and Plasma tvs.In to 1 or 2 maybe 3 to 4 years old in used.The power supply board have these componnents parts call the capacitors,it will started to bulges up on it top,or puff up on it top.These capacitors are leaking gases and it dead.The tv will not power up and the LED power lite indicator start continuous flashing LED light.U know basic electronic's and soldering?Take the tv aparts where the power cord plug into it that ur power supply board.Searches all around the power supply board and it supporting boards,replaced all those dead gas leakage capacitors.Ur tv will power up normal again and work.Or Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 24, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Does replacing the motherboard affect the files i had saved?
yea when u replace your motherboard u will still be able to get your old files, it will not disturb your previous data. coz your data store at Hard Drive n you are goint to change only your m-Board...
so good luck
shafky
Jun 20, 2009 | HP Pavilion dv9000z Notebook
2001 grand cherokee ltd completely lost power
Check the connections at the battery. Be sure they're clean and tight.
May 09, 2009 | 2001 Jeep Grand Cherokee
Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
Apr 21, 2009 | Bose Lifestyle 48 System
Dead remote
try rebooting the remote control by removing the batteries, then press every button one time, replace the batteries with a fresh set and give it a try. If the remote still fails to work contact remotes.com for
Nov 24, 2008 | Televison & Video
LG 37 LCD
The backplane lamps, and or the backplane power supply is probably starting to fail. This is common in LCD sets.
In some models, the backplane parts are replaceable. In other's the complete display has to be changed.
Call the factory service rep in your area to arrange to send them the set for an estimate to service it.
Jerry G.
May 25, 2008 | LG 37LC7D 37 in. LCD HDTV
Sreen says amp error
The audio Amplfier IC are damaged.
May 22, 2008 | Pioneer Audio Players & Recorders
Dead tv
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
May 22, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Toshiba SD-3980 DVD Player Logo
229 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
