Question about Home
I want to replace a kitchen light that has old wiring with a new wiring harness what is the the old wiring system for neutral and live
The old system has 3 seperate black wires and 2 red wires
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Send a picture using a volt meter to determine neutral and hot works too
Posted on Apr 14, 2013
2 Suggested Answers
gotgeek2
  • 565 Answers
SOURCE: hi my question is motion spot light has has two
The red wire from motion detector connects to both of the black wires from the lights. The black wire from the motion detector connects to the incoming black wire from the switch or source. The white wire from the motion detector connects to both of the white wires from the lights and to the incoming white wire from the switch or source (all white wires are under one wirenut).
Posted on Dec 18, 2010
2003 vz800 was in a small fire. Looks as tho only some burnt wiring. Replaced the main wire harness and now the fuel pump clicks on ignition and the neutral light does not come on when it's in neutral
The neutral light is a simple circuit ,when the ignition is on there should be a live feed to one side of the neutral light bulb holder the other side of it (earth) goes down to the neutral light switch which is earthed when the gear selector drum touches it(a bit sticks out) when in the neutral position.so it's either a fault with the switch or the wire from the switch to the bulb holder is not connected or there's no live feed to the bulb.you can just take the wire off the switch and touch it on a clean piece of the engine with no paint or lacquer on it if the neutral light comes on then the switch is faulty.
May 03, 2015 | 2003 Suzuki VZ 800 Marauder
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
JEC0530ADB I have a 6/2 cable with ground presently can I use this wire for my new cooktop JEC0530ADB. Do I need a neutral for this unit.
The current cooktop worked with the 6/2 and thusly the new one should. It defiently advisable to use 6/3 wire but not necessary. It in essance already has a neutral using the ground, if the old one has any indicator lights that worked it used the ground as a neutral to complete the hot&neutral circuit necessary to light the indicator light. The indicators work off of a 120 volt circuit and 240 is needed to heat only
Aug 04, 2011 | Jenn-Air Kitchen Ranges
We have a twenty year old electirc jenn-air range with vented cooktop. the oven and range top both stopped working. digital clock only worked when light was turned on. repair man said it was not geting...
The problem may well be a loose NEUTRAL wire to the range. At the wire terminal on the range check for power from each supply leg(L1 to N) and (L2 to N) to neutral(should read 120 volts) and across each power leg (L1 to L2) should read 220 volts.
If you in fact have 220 volts into the range with good neutral contact the problem is a bad neutral(ground) in the wiring harness inside the range.
Sep 29, 2009 | Jenn-Air Kitchen Ranges
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
My hyosung has stop runing it has no lights nothing is workeing at all can you tell what it can be
  • Is the battery 2 or more years old? It may need to be replaced. Check the fuses.
  • Before charging, add water to fill each battery cell to nearly full. Distilled water works best.
  • Use a 1amp or a 2amp battery charger
  • Is the kill switch on? Does the side stand have a kill switch? Is it working properly? Is the gas valve on?
    If no spark, then check again but with a new plug.
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wire harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and wire connection on the center gearbox casing.
Apr 16, 2009 | 2003 Hyosung RX 125
Fan oven element not working
getting a shock just means that live is connected. if no heat, that means that no neutral assuming element is ok. do you have a multimeter so you can check if live and neutral present at element? are you sure old element was faulty as it seems strange that putting in a new element did not cure problem i have a memory that there may be a fan fail stat mounted close to the element. worth a check
Apr 01, 2007 | Rangemaster Professional 110 (Duel Fuel)...
Home Logo
47 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
