SOURCE: lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
