Whirlpool Duet Washer Display 8:88
I have a Whirlpool Duet Washer (GHW 9100 LW2). After a power outage the display shows 8:88. I have tried resetting the unit many times but 8:88 continues to show on the display. Can someone help me?
  • jessie Feb 13, 2012
    My washer unit is a front loader
jsrock516
  • 5911 Answers
SOURCE: button start locked my clothes locked inside washer duet whirlpool ghw-9200lq
If you suspect you have a defective door latch, you should be getting an error code of "Fdl" displayed on the console as well. This may just be a matter of a malfunction where the latch became jammed. You can still get your clothes out of the washer by removing the lower panel under the door. There are 3 torx type screws under the bottom edge of the panel. After removing the panel, place your hand inside the washer behind the front casing where the door latch assembly is. Try to locate a plastic tab at the very bottom of the door latch and pull straight down. This is a manual door release and the door will open, allowing you to retrieve your clothes. With the door opened, try closing it again. Select a wash cycle and push start. Listen to see if you can hear the latch lock. Push PAUSE/CANCEL to stop the cycle and listen to hear if the latch unlocks when the cycle stops. If you definitely have a defective door latch, follow these steps to replace it:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub. This requires more steps, which means removing more parts, which means more time (plus patience).
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom.
Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in. At the control panel select:
DRAIN SPIN
NO SPIN
and under OPTIONS press any key (has the be the same key) 4 times.
This places the washer into diagnostics mode. "C00" will be displayed on the screen and you should hear a distinctive "click" of the door latch. If diagnostics passes, the washer will run through a series of tests, tumble, drain and then spin. When completed, the unit will make an audible "beep" and the CLEAN light will be lit.
You can stop this process at any time by press the PAUSE/CANCEL button. Good luck to you and let me know if you have any further questions.
Posted on Feb 10, 2008
  • 958 Answers
SOURCE: Still getting FH codes
does you unit have this water sensor at the bottom part of the unit?... if so..sometimes they get too sensitive and dictates an error message.
you can experiment by dsconnecting this wire and if it does not change anything, then short the wires. i am not sure if this is a normally open switch or a normally close switch.
if you jumper a wire on the two wires and it indicated a different error code, then it is a normally open switch. remove the jumper wire and w'e'll continue trouble shoot your unit.
tnx for using fix ya.
drcool
Posted on Aug 19, 2008
localwonder
  • 6784 Answers
SOURCE: duet will not start
HI, The Central Control Unit has failed. you will need to replace this failed control board asap.
We recommended a service call for this type of repair.
Posted on Jun 22, 2009
canbruce75
  • 1776 Answers
SOURCE: Is there a way to
If the machine is underfilling, check the water level switch. This diaphragm like device has a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to advance to the appropriate cycle. Make sure the plastic tube has no damage or obstruction. An obstruction can cause the switch to be activated too early.The switch can be tested for continuity using a multimeter or ohmmeter. A lack of continuity would indicate a faulty switch. Hope this helped and best wishes.
Posted on Aug 09, 2009
milten1
  • 1304 Answers
SOURCE: whirlpool 9100 lw2: water does not shut-off, i
your water mixing valves are leaking by
this is a very easy repair
three screws keep the top down on the back
slide the top backwards then lift
the water valve is right there on the back wall
call apliance parts pro
877-477-7278
order part number AP3128776
41.00 a few dollars cheaper than sears
Posted on Oct 14, 2009
My Whirlpool Duet washer model GHW 9100 will fill with water then a clicking sound starts the time flashes and will not run the wash cycle. What are the possible problems and id it worth repairing?
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&^^
Aug 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet model # ghw 9400 lo.door locking problem.
One hour service plus $40 part.
Feb 14, 2010 | Whirlpool GHW9400 Front Load Washer
Waher stopped with an sud code and will not do anything. water is in washer.
too much suds in washer--
try using HE detergent-
reset to rinse cycle I think will work-been awhile since I had that code-
ready to throw my GHW 9150 off a cliff-FDL codes-door locks up.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet will not start
Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET 9100 STOPPED UP DRAIN IN SPIN CYCLE F02 BLINKS.
I looked up a pic of a model ghw 9100 for you to look at as reference. There is a kick panel with three screws. Either a 1/4 inch socket or a torx T20.
Oct 16, 2008 | Washing Machines
Whirlpool Duet Sportwon't respond after power outage
IF YOUR MACHINE IS A WHIRLPOOL DUET TRY THIS ;
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Good luck
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW 9400P
Hello! your problem is the motor control unit,MCU.
or the central control unit,CCU. Try unplugging the washer for a few minutes sometimes that will reset the unit.There is a tech sheet inside bottom of the washer cabinet.If youre not sure, may need a service tech.
Dec 17, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
