Question about Samsung SyncMaster 2253BW LCD Monitor
Samsung 2253BW will not power up
I unplugged my 2253BW from the AC power while it was connected to my PC. When I plugged it in to AC again it would not power up. On-Off switch does not turn on power, No lights or screen activity. Is there a reboot or other setting that needs adjusting?
SOURCE: trying to connect samsung 2253 bw lcd monitor to new computer
changed connections
Posted on Aug 24, 2008
  • 4 Answers
SOURCE: Samsung syncmaster 2253BW blurry/out of focus HELP!
cables wont make a difference, are you sure your display settings are set to 1680 x 1050? i have had problems when it is set to 1600 x 1000 and i had to reinstall the video card drivers.
Posted on Jan 09, 2009
  • 4 Answers
SOURCE: Samsung 2253bw lcd monitor makes loud, fast
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Posted on Jun 05, 2009
SOURCE: Auto adjust doesnt work
try to push the menu button for 5sec, maybe it will be solve the problem..
Posted on Aug 11, 2009
Toshiba satellite c655 won't power up
Take off the top keyboard and power lid. Check for damage to the power flex cable. Plug in AC adapter. The port where connected power flex cable should have two or three pins. With small screwdriver try two-pin jumper shortly. Does not turn on again? All you need to replace the motherboard
Oct 04, 2013 | Computers & Internet
Samsung notebook N150 Plus has gone completely dead
Try another AC outlet, try another cord/charger of the EXACT same power spec. Has the AC jack in the computer been damaged by pulling on the cord? Power surge? With a multimeter, verify DC volts at ac cord plug. Is the Laptop usually left plugged it when not in use? Do you shut it down and unplug when not in use?
Jan 20, 2013 | Samsung N150 Notebook
My Q430's power connection is loose and not changing battery. Do I have to swap out motherboard?
The DC Power Jack is the jack you plug the AC adapter (Charger) into. (DC_IN)
The DC Power Jack for the Samsung Q430 series of Notebook PC's, consists of a;
1) DC Power Jack, which is connected to two wires.
2) The wires end in a small male plug connector.
It is now a DC Power Harness,
http://www.laptopjacks.com/part/Samsung-Q430-DC-Power-Jack-J-SM371300C1.html
FOLLOWING Anti-Static Procedures, the laptop is disassembled far enough to unplug the DC Power Harness, and plug a new one in.
Regards,
joecoolvette
Sep 10, 2011 | Samsung Q430 Laptop
Dear Guru, im Peter thanks 4 ur quick response however my problem still remains with LED samsung 40''...i have no display just standby red light it connected with cable (satellite televion) and remote...
Hello Peter, my suggestion is unplug your cable satelite (STB) conection.
Turn on the TV and see if there are changes or is still standby.
If your TV like normal after unplug satelite tv (STB) connection, you should check you STB.
If still not working, try to unplug AC cord from power line. Wait until led display indicator off, that plug again. If it still not working, i think you should call samsung technician to check you tv.
thanks.
Mar 17, 2011 | Televison & Video
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
SyncMaster 2253BW LCD Monitor doesn't fill screen in game's
you can change the size of the screen by going to the set up screen (menu) then adjusting the third box down the coarse and fine and the verticle and horizontal positions my settings are course 1798 fine 48 h position 56 v positiion 50 hope this helps regards Jim
Feb 14, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Dec 28, 2008 | Samsung SyncMaster 2253BW LCD Monitor
Flashing Off
save your self the trouble if you have a flat screen TV you can connect to it NOW! if you need a second monitor you can go to a goodwill and buy a monitor under $40.00 I think is a good choice.
Feb 08, 2018 | Samsung SyncMaster 2253BW LCD Monitor
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Open Questions:
See all Samsung SyncMaster 2253BW LCD Monitor Questions
Samsung SyncMaster 2253BW LCD Monitor Logo
97 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
