Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
New battery, new starter & still problems starting
  • Bob Adams Feb 16, 2012
    Purchased the mower new in the spring of 2007. Thanks for your suggestion, but before I had the chance to do anything with the fuel pump or carb, my neighbor walked over with another thought. He has the same engine and had the same problem last year. He said to adjust the valves before doing anything else. It took about 15 minutes and worked like a charm. In addition, while I was at it ..........new plugs and gas filter.
  • 1,868 Answers
Hello! How long have you owned it? Question is directed at the carb and fuel pump...I would suggest rebuilding the carb with kit and replacing the fuel pump at the same time...see photos below...There are a couple of different fuel filters; one for a non- fuel pump (gravity feed) and one with a fuel pump...Your engine requires the fuel pump filter...dirt and varnish build up in the carb and pump especially if the wrong filter is installed...Buy a gallon of carb cleaner with the tray inside...
Guru...saailer
Genuine OEM Part - Manufacturer #808656...$18 Fuel Pump
Genuine OEM Part - Manufacturer #691035...$6 Filter
Genuine OEM Part - Manufacturernew battery, new starter & still problems star - 2_14_2012_12_27_48_am.jpgt
Posted on Feb 14, 2012
New battery & starter. Car wont start. Starter clicking.
sounds like solenoid has failed or is sticking
Jan 08, 2015 | 2002 Ford Taurus
I have 1999 GMC suburban, it will not start without and boosted
Have you never had a problem like
that, since you started driving?
Start testing things-- to find a problem
Is the battery dead,old,worn out?
Have it tested
Test the starter & solenoid
Examine & test the battery cables
& many other items effecting the starting system
Won't Crank (turn over)?
or
Won't Start?
Won't Start check for fuel pressure,spark,injector
pulse & so on
Oct 04, 2014 | 2003 Chevrolet Suburban 1500
Truck won't start we put a new starter on put still nothing,but it will start if you use a screwdriver between the starter terminals, we have a 2004 dodge pick-up
Then the battery,it's cables to ground & the starter
are good ,as well as the new starter.
So you know where the problem is !!
The control circuit from the battery to a fuse, to
the ignition switch,safety switch or switches,where
ever they are,possibly a starter relay
Would be nice & probably necessary to have
a wiring diagram, so you know where to start your testing
Aug 02, 2013 | Cars & Trucks
06 pontiac grand prix wont start no clicking when you turn the key over even jump starting the battery, has dash lights & radio & parking lights. battery tested good. put a used starter & altinator on
Used parts such as starters and altinators don't last. It might **** but it sounds like you need to buy a new starter,altinator, and battery. Or just start with buying one at a time.
Dec 06, 2011 | 2006 Pontiac Grand Prix
New battery new starter nothing happens when i turn the key
You definitely have a starting system problem. You have two circuits - Battery to starter circuit & the Starter Control Circuit (Ignition switch, Transaxel Range Switch (if Automatic Trans), Starter Relay, Starter Clutch Pedal Position Switch (if manual Trans) Fuse & Starter Solenoid). Based on your description, the problem is in the Control Circuit.
Here's an illustration:
Sep 05, 2011 | 2000 Hyundai Elantra
2001 Expedition won't start sometimes. Took it to auto zone said it wasn't battery alternator starter is pulling to many amps. So check starter connections first then put new starter on. Would like 2nd...
Hi, Usually starter draws the current about 300 Amps to crank the engine. If your car is not crank, the problem is either on your battery or starter relay/solenoid. If car crank but it does not start, the problem are on ignition, fueling.
In your case, I think just check the current draws of starter ( auto zone has done, but no data) compare it with new starter. If there is significant difference then they are correct. In contrary,then the problem is not on your starter, it could be your battery.
Regards, vote please, Jay
Jan 23, 2011 | 2001 Ford Expedition
Car cut out like no ignition, now no power to starter circuit. Battery new & hot
No power to starter circuit.The starter gets power from battery to start.So check the connection between battery to starter.As you mentioned battery is new ,but still get the battery voltage checked.It should be 12 volts if battery is fully charged.If battery shows 12 volt then check the connection terminal from battery to starter.If connection checked ok then its most probably the problem of faulty starter.It has to be replaced.But if the starter checked out ok by meter, then the problem relates to faulty ignition switch circuit causing this problem.Checking all this possibilities will rule out the exact faulty part causing the problem.----------Thanks.Helpmech.
Dec 02, 2010 | 2002 Ford Taurus
I had a problem with my starter solenoid my truck was not starting. i have a 1996 ford ranger i bought a new one the truck started a few times and then it stopped. what is my problem.
You should have your battery tested & make sure that the terminals are cleaned & well protected wth grease once charged fully. Since you crossed/jumped the solenoid & didn't get it to start until jumping the battery (providing extra voltage), that rules out the solenoid and the ignition switch. Sometimes a battery will test full without a load but will not provide the voltage to the solenoid to actually complete the circuit, thus the clicking sound. If the battery is strong, and the starter bad, the solenoid will click solidly once, passing full voltage to the starter that will either turn,hum, or do nothing. good luck
Jan 29, 2010 | 1996 Ford Ranger SuperCab
How do i put the starter on the car myself?
undo the possitive battery cable jack car up in front place jack stands under the A arms for support unbolt starter from transmission & all wires get new starter & replace all wires on new new starter put starter back in bolt it down & make sure all bolts are tight & reconnect battery & it sure start
Nov 10, 2009 | 2000 Dodge Neon
I have 91 4 runner new battery & alternator & new starter
did you check all the fuses and the main fuse under the bonnet try to give thr starter a few taps with hammer not hard if starts then it is brushes in starter ,does light come on on dash if you put key in on position
May 17, 2009 | 1988 Honda Accord 4 Door
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
195 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
