Whirlpool washer
Stops add garment flashes then turns off. This happens in quick wash and normal wash modes
  • Mike Feb 14, 2012
    Worldpool Duet sport model #wfw8300sw05. This happens with all cycles. Quick cycle is 25 min at 19 min the add garment light flashes then the unit turns off.
  • 1028 Answers
SOURCE: I have a Whirlpool Duet
the add a garment light will stay on through most of 1st wash this lets you know that if you forgot something it can still be added ..if not already overloaded..by pressing pause the door will unlock and allow something to be added ..yes it's normal
Posted on Aug 11, 2008
SOURCE: whirlpool awo 3761/5/s
have you checked that there is not a blockage in the outlet pipe or that it is not kinked?sometimes if the pipe is lying to low (ie creating a u-bend) this can prevent water getting in & out & so the machine interprets it as either taps off or the pump needs cleaned (this has happened to me numerous times :) )
Posted on Jan 12, 2009
SOURCE: Washer control panel flashing and won't restart
I don't know if this is a real solution but it wokred for me. I just unplugged it for about 10 minutes and then plugged it back in. The flashing stopped and I was then able to resume normal function.
Posted on Mar 08, 2009
  • 240 Answers
SOURCE: Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Posted on Apr 26, 2009
buffalonyman
  • 1865 Answers
SOURCE: I stopped the washer to add a garment and now the
Unplug the machine for a few minutes to reset the controller
Posted on Aug 17, 2009
Door won't open, Add Garment Light flashes
Not enough weight in the washer I am guessing. Try adding more clothes.
Jan 06, 2015 | Whirlpool WFW8300SW
Machine was working fine but I stopped it twice to add new garments now the add a garment and wash light are on but when I try to start it nothing happens
its a washing machine built be a man so its none to smart you have confused it to much by asking it twice to do the same job,,,,,,try turning it off then give it time to forget the last job you give it to do, turn it back on and tell it to rince and spin,, that may help it get its drain back in the box?
Nov 24, 2010 | Whirlpool GHW9400 Duet Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
I have a whirpool duet. the door is on lock mode and i can not cancel. what can i do
This has happened to me...unplug and plug back in. If possible, start the machine on a normal wash cycle. It will start, then the door will unlock at the 'add a garment' portion of the cycle (usually a few seconds into it). Hope this works!
Jan 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Feb 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Sport, brand new. It keeps asking to add a garment when the washer is jam-packed with clothes. Is it a malfunction, does the "add a garment" light ever shut off?
Aug 10, 2008 | Whirlpool Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
