Question about HP COLOR LASERJET CP 3505 N PRINTER
10.92.03 error code 10.92.03 on hp clj 3505
4 Suggested Answers
  • 81 Answers
SOURCE: 59.c0 error in hp clj 3505 printer
Looks to be a motor error that drives the cyan toner cartridge. try swopping the cyan toner cartridge first because they can go stiff and hard to turn when they get older, this will then slow the motor down and cause a service error
Posted on Oct 14, 2009
  • 81 Answers
SOURCE: getting a 59.c0 error on hp clj 3505
Is the transfer unit installed correctly?Check and refit the transfer unit.
Posted on Oct 15, 2009
pctech1
  • 1940 Answers
SOURCE: hp clj 3600 error code
51.XY ERROR
alternates with To continue turn off then on
A printer error has occurred.
X Description:
2 laser
Y Description:
0 Black
1 Cyan
2 Yellow
3 Magenta
Your error then comes from the magenta laser.
The recommendations from the service manual are:
  1. If the message persists, turn the printer off and then on.
  2. Reseat DC controller connectors J1022, J1026, and J1027.
  3. Reseat laser/scanner unit connectors J101A, J101B, J5001A, J5001B, and J5020.
  4. Replace the laser/scanner unit as necessary.
  5. Replace the DC controller PCB as necessary.
Posted on Mar 08, 2011
Have a 59.30 error code on a hp clj 5550
My printer displays a 51.23 error, what to do? hp laserjet pro cm 1415fn color mfp
Oct 09, 2013 | HP Color LaserJet 5550hdn Printer
Hp laser jet cp3505 printing only black and white pages.not printing colour
Its mechanical mis alignment problem,remove main motor assm which is located right side,you will find out four gear wheels row enguaged with other gears.. Upper 1st gear drives the mono catridge, remain three ment for colour catridge drive. Open this mechanism & absorve that each gear having align markings marking.If this alignment got distrubed you will get quality issue. Its very easy to understand to match each gear, take help of service manual suits clj 3600,3800. Try it...if fails try it up to sucess.... Best of luck..Vinay.
Sep 05, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
50.2 code on a hp 3505
Hi:
A 50.2 error is a fuser error. This is the assembly that heats up and fusees the text to the paper. It is located at the top of the printer. The fuser is not warming up and is throwing this error. The fuser would have to be replaced.
Andrew
Aug 09, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
For those users who are having a problem with the printer motor, this C level problem is referred to as 'developing disengaging motor rotation error'. Most likely, this problem points to an issue with the function of the DC controller: either it has failed or it has affected the developing disengaging assembly. The solution is quite simple and the user may fix the error in a matter of few steps.
The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller). After connecting these two connectors to each other, the user must replace the developing disengaging drive assembly directly.
The final step is to replace the DC controller PCB, after which the printer is to be recalibrated. for more information....
http://www.fixya.com/support/t503092-59_c0_error_hp_color_laserjet_5550
Oct 14, 2009 | HP Color LaserJet 3500 Printer
I have a HP CLJ 4700dn printer which keeps on giving 49.2FCC
That error is a firmware error, you might try again to download and install the update, or try a new memory stick if you have additional memory installed.
Jun 22, 2009 | HP LaserJet 5550DN Printer
Color Laserjet 3505 13.20 service error
There is a set of sensor flags on the bottom of the paper input unit (paper feed assembly). You may be able to see them if you take out tray 2, remove the toner cartridges, and turn the printer on its back. One side of the rod can get stuck, it will make it look curved, it should be straight. "un-stick" the stuck side (typically the left side) so the flags can move freely.
Apr 03, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
Eror message 49.4401 on hp clj 5550
Dec 15, 2008 | Office Equipment & Supplies
HP COLOR LASERJET CP 3505 N PRINTER Logo
102 people viewed this question
Ben Johnson
