Canon ir6800c e000061-0003
I've formatted the ram >>> unplugged the power cable and put it into the floor to free any charges >>> and the error appears once the machine starts to print.... ANY HELP!
  • Mahdi Ahmadi
    Mahdi Ahmadi Jun 08, 2013
    i have a canon ir6800c but its printer controler is not unable . how can i unabe printer controller on it?
checkitright
  • 1362 Answers
SOURCE: canon ir6000 error codes E000061-0001..
E061 Specific potential is not required or the limiter is activated as the potential is controlled.
I beleive it is the Potential of the "drum sensor"
there is a sensor that reads the drum and adjust the machine, this may need to be adjusted, cleaned or replaced. Has to be done by a tech.
Posted on Aug 25, 2008
michael464
  • 8 Answers
SOURCE: Incompatible ink cartridge(s) ERROR on HP 4230 All-in-on printer
Try uninstalling and reinstalling the drivers. This can be done by going to the Add and Remove programs, this is located under the Control Panel. You may have to reboot and I would recommend that you do. This will clear out the Print Spooler. The Print Spooler is located under the C Drive and may get corrupted. You can find information about this in Google. Look for repairing spooler on the OS that you are using.
Posted on Dec 31, 2008
SOURCE: Error code E20 in Canon NP 6241 copier
Check this code - does it read E020 ? if so this is usually a result of toner starvation possibly caused by a faulty toner sensor in dev or hopper unit.I have also found the toner hopper supply motor can fail with the same result. In either case it is an engineers job to rectify. Good luck !
Posted on May 19, 2009
cene765
  • 787 Answers
SOURCE: canon error code 6500
It's a hardware error.Your printer need service.
Posted on Oct 08, 2009
sfigurasin
SOURCE: Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Posted on Mar 31, 2010
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
Powerspec b820. How do I add a new HDD
>Power down, and unplug the computer.
>Remove the Left cover (when facing the front); there are 2 thumb screws top & bottom on the rear. They go through the black edge of the cover and thread into the case. The side cover pops off.
>Locate the hard drive, unplug the two SATA cables (power and data) from the hard drive; leave them plugged into the motherboard.(see picture)
>There are two screws that hold the HDD (Hard Disk Drive) in the bay; remove them. There may be two on the other side (sometimes not). If so, you will have to remove the other side cover in order to access them for removal.
>The HDD will slide out the rear of the bay.
>Slide in the new one, reset the screws, replace the cables, and put the side cover(s) back on.
You're done and ready to format and install your operating system.
See the attached picture for clarification.eaa0cf82-6180-4457-87ca-281f3b46185a.jpg
Oct 07, 2013 | Powerspec B820 Desktop Computer; Intel...
My computer will no longer recognize the memory
Hi.
Try this >>>>
Remove the power cable and lay the computer on its side. Remove all the RAM from the unit ad make sure all the brass contacts are clean. After that take a look at the slots and make sure they are free of any dust.
Plug in the power cable and start putting the RAM back in one at a time turning the machine on with each module to try, that will determine which of the modules maybe faulty, it just maybe a case that you haven't put them in properly.
Good luck and regards.
Jan 01, 2013 | Computers & Internet
HOW CAN I SOLVE "THE TONER IS NOT SET INSERT THE TONER" ERROR ON MF3220 CANON, I've checked the sensor and cartridge gears.
TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
Dec 29, 2012 | Office Equipment & Supplies
The yellow light comes on inside but the computer won't come on neither does it beep?
First remove any power cables and batteries(if laptop) from your system and hold down the power button for 15 seconds.
Plug the power cable back in & attempt to boot.
If this does not solve your problem then you will need to remove all non-essentials from your system.
If laptop, this simply consist of battery, ram, optical drive & any other removable bays or devices. Unplug all cables except the power cable & attempt to boot.
If desktop, you will need to remove any cables plugged into your computer except keyboard, mouse, power, video, sound, & network cable. Open the case & remove any PCI cards, except video cards, unless you have on-board video, unplug the data & power cables going to the optical & hard drives. Now attempt to boot. If you have no luck you can remove your RAM sticks & try again. If you get an error beep warning you about no ram then you might have a bad ram stick. If none of the above works then you may have a bad power supply or motherboard. Power supplies are pretty easy to test with tester or use a spare.
Jul 16, 2012 | Dell Computers & Internet
A week ago my dodge ram 1999 5.2l 4 wheel drive lost it's abilitiy to speed up properly. it goes pretty slow as there are no power. By the time I get to 30 miles an hour, I've gone 3 blocks. when I...
Clogged Exhaust Converter --put money on it
Clogged Gas Filter-- maybe --- if in there over 6 years
Tps Sensor-- at least have it checked out
O2 Sensors -- most likely worn out & not controlling
fuel trim
Going to assume you know about the spark plugs,rotor,cap
air filter etc..& no chip monks took up home in the air filter box
Never by pass the battery voltage & alternator output & alternator
diode problems putting out A/C voltage
Sep 20, 2011 | 1999 Dodge Ram
I have download Adobe Reader X 10.1 version to replace 9, but I cannot open some PDF files from internet error code is 103:103 why? and how can I solve this problem?
There's a discussion of this problem on Adobe's forum at
http://forums.adobe.com/thread/771034.
Maybe some of the ideas there will help.
Have you tried Foxit Reader? It's for .pdf files and I've had very good luck with it. Download it for free:
http://www.foxitsoftware.com/downloads/
Aug 24, 2011 | Adobe Computers & Internet
I 've a DELL vostro 1015, it's new but i've a problem with the RAM, after just 6 hours of work (not hard work or programming) there's no more space in RAM 'n i've to restart or the...
> It is new
Then, it's protected by Dell's warranty, and you get at least one FREE telephone-call to Dell's Technical Support. Make the call.
Jun 25, 2011 | Dell Vostro 1015 Laptop
Desktop Freezes and lockups..... I've changed out ram, I've tried new hard drive and trying to do a reinstall and it locks up during reinstall.... Opened and cleaned fan and residue underneath fan...
remove power cable, remove ram, remove small battery from motherboard, , paper put in small water, and with it clear ram contacts /only ram contacts/, then put all in teir place, turn on, if it will be lock again, you need chnage power suplay.
Jun 07, 2011 | HP Pavilion a6347c Desktop /Athlon 64 X2...
304 people viewed this question
k24674
