Question about Air Tools & Compressors
Where is throat packing nut located
Need to find where to put throat seal liquid
What type of oil does the 440 titan impact use
No oil! but you have to use throat seal at the pump piston
Jan 04, 2015 | Titan Airless Sprayer Owners-service-parts...
How to replace a rear transmission seal
Hi Friend: My name is David i'll be Assissting you today.
#1) First get you a Drain Pan put underneath truck where the Tail Shaft is located you'll loose some fluid when you remove the Rear Transmission Seal.
#2) You might need to Jack up thr rear of your Truck to give you more work space.And Secure your Truck with good jack stands and Also Put some Wheel Chucks (Blocks in Front of your front Wheels to prevent it from rolling forward on you.
#3) Next you'll need to remove your Drive Shaft, There are Four (4) Nuts on the Rear of the Drive line where it connects to your Rear End on the Front Side of 3rd Member.
#4) The (4) Nuts are Hold 2-U-Clamps 2- Nuts per Clamp, Take off the 4 nuts Tap the drive line with a Plastic Mallet this will loosen up the U-Bolts Save all your Nuts ,you'll need them to put back on the U-Bolts to get Drive line back in and Tight.
#5) You might have to use a small pry bar to FREE Up the Drive line Universal Joints and push the Drive line Forward just enough to get Drive line away from the Rear End.NOTE: becareful not to let the 4-Universal Caps come off the Universal Joint.Take some Black Tape and Just Wrap it Around ALL 4-Of the Caps to hold in place until your ready to put back in.
#6) Now Pull back on the Whole Drive Line Slowly and it will Come out of the Rear of your transmission.Thats where your Rear Seal is Located.
#7) Get the Proper Tool to Remove the Rear Seal from the Tail housing, (Seal Remover) and remove it from the transmission.
#8) Now Using a Seal In-Staller You'll line your new seal up to the Tail of your Transmission.Evenly And Tap your New Seal in ,it must be Tapped all the way in until its flush with the Tail Housing.
#9) Now you just Reverse the Removal Instructions( take Off the Tape) and put your Drive line back in. Just put your truck in Neutral so you can get the Rear Cups to line back up in the rear end.
#10) Make Sure you are lined up now put your U-Bolts back in.
And the Nuts on and Tighten up good and Tight.
Don't forget to put back the Transmission Fluid Lost.and after Starting Check and Make sure your Transmission Fluid is up to the FULL line.
This will get you back on the Road Sir.Thank You for Using FixYa Please let me know how my solution has helped you by Voting Thanks Again. From: d_hubbs
Aug 21, 2010 | 2004 Chevrolet Silverado
How hard is to change front bearings and special tools??
No special tools, not hard, get the parts, rubber gloves, can of grease, and a couple hours time, turn off the cell fone. Pull the wheel, remove dust cover, pull cotter pin, remove brake caliper, hang from wire, remove nut on spindle, bump rotor with rubber mallet, the bearings should pop out, pull the hub off, knock out the inner seal and bearings, replace with new bearing packed with grease, replace seal, put hub back on, put on outer bearing, packed with grease, washer, nut, tighten up snug by hand, then back off so wheel spins free and doesn't rock, put in cotter pin, dust cover, caliper, tighten up, your all set. Too tight will burn up bearings, too loose and you will hear it rocking back and forth. Hope this helps.
May 03, 2010 | 1996 Ford Windstar
How to replace rear wheel bearings
If it has drum brakes, you'll need to take off the center dust cap, remove the cotter pin, remove the nut and washer holding the drum on. The outer bearing should fall out, the inner bearing usually stays in the drum, due to the grease seal. With the front bearing and washer off, put the drum back on and install the nut, then pull the drum, allowing to the nut to catch the inner bearing as you pull off the drum, and that should leave the inner bearing and seal on the spindle. Pack the new bearings with grease, install the inner one in the drum and tap in the grease seal in place, but the drum back on and install the outer bearing on the spindle, the wash, nut, cotter pin and dust cover. Tighten the nut snug and turn the drum a few times and snug up the nut. Don't overtighten it.
Apr 29, 2010 | 1991 Volkswagen Jetta
I need to reploce the front left rotor on a 1996 ford econoline van. I need to know how to remove the bearings from the old one and put in the new one. Plesae help
Once you remove the center cap, remove the cotter pin, and remove the nut and washer, the outter bearing should slide right off. Remove that, and put the nut back on, then pull the rotor towards you, allowing the nut to touch the top of the inside of the rotor, until you catch the inner bearing on the nut, then give a ****, that should leave the bearing and seal left on the spindle. If not, you can use a seal remover, to get out the seal and the bearing will fall out of the rotor. Pack the new bearings and install the inner bearing, tap in the seal in the rotor, install rotor, install packed outer bearing and install.
Mar 12, 2010 | 1996 Ford Econoline
Packing front wheel bearings
what I do is put a glob of grease in the palm of my hand and push bearing down in to grease untill you see the grease come out of the bearing or you can go to your local parts store and get a bearing grease packer. also wipe spindal with a genorus glob and put grease in between bearing in rotor. To get to the bearings all you need to do is remove tire, center cap (outter grease seal) the silver cap in the center. the cotter pin, Nut, washer outter bearing then the rotor will slip off inner bearing is in rotor still being held in by inner grease seal take seal off replace with new one pack your bearings and reverse removal procedure when retightening nut do not make tight just snug the go another turn if you go to tight you will burn your bearings real fast.
Apr 07, 2009 | 2002 Ford F250 Super Duty SuperCab
How to change c.v joint
Remove wheel, brake caliper and disc, end cap and circlip (if fitted) 6 bolts that hold the hub drive, undo and remove the hub nut by knocking back the lock washer, remove the inner hub lock nut and remove the hub assembley. remove the 6 bolts that hold the hub shaft and remove that.There will be either oil or liquid grease in it, Now you will see the drive shaft and CV joint, just pull it out. Clean all the oil or grease.knock off the old CV joint and knock on a new one, they have securing clips inside but will knock off with a hammer.refit is reversal of removal. Use silicon sealant to seal the hub shaft when you put it back. You will need to fill the swivel assembley with liquid grease. you will see the filler plug on the swivel housing, put in about half a liter Its possible you may need to replace oil seals, check as you go along. to adjust the hub play, tighten the inner hub nut until it goes tight then back it off until the hub can move freely and effortlessly, then grab the hub and pull back and forth to see how much play is there, a little is permissable, so adjust to suit. Fit and lock the washer and tighten the outer locknut. Then as i said refit as you removed. These are safety related parts , so please make sure the items are tightly secured, aftreall you dont want the wheel to fall off.
hope this helps
Feb 10, 2009 | 1994 Land Rover Discovery
Air Tools & Compressors Logo
203 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
