Question about Precor Exercise & Fitness
Reset precor m7.2 stepper - Precor Exercise & Fitness
I get a error 05 code on my precor treadmill C932/C964
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 05, 2014 | Precor 932i Treadmill
Corrective Action
ER 05 displayed on precor 9.31?
Corrective Action
Nov 23, 2013 | Precor Exercise & Fitness
Precor EFX 546 05 stuck key
Corrective Action
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
Treadmill precor 932 er05 error
Corrective Action
Mar 31, 2013 | Precor 935 Premium Series Treadmill
I have a precor 935 that is showing error 5 stuck key that wont clear. any ideas
Corrective Action
Feb 01, 2012 | Precor 935 Premium Series Treadmill
My EFX elliptical provides an error 44? and shuts down in the middle of my work out. I notice this is only an issue when choose a course that is weight loss when the EFX has to incline and decline. When...
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Jan 21, 2011 | Precor EFX 546i Elliptical Version 4
My Precor EFX 546 Elliptical machine has a "key depressed" error message.
Corrective Action
Aug 17, 2010 | Precor EFX 546i Elliptical Version 4
Precor 9.25i Treamill scrolls message "button is pressed"
Press Enter,speed up and speed down simultaneously. Then enter to view error buffer . press quick start/pacer-stop simultaneously to reset error buffer log. Hope this helps
Apr 06, 2010 | Precor 9.21 Treadmill
Exercise & Fitness Logo
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
