Question about Canon MP49D Calculator
I have an MP49D calculator problem showing an E on the left hand side that comes up during calculations. It abruptly stops my calculation during various functions. ???
SOURCE: Calculator is stuck in Binary mode
Try this. Press MODE and then number 1 ... This worked to me. And then with DRG you can change to DEG, RAD or GRAD ... I hope I helped :)
Posted on Dec 13, 2007
SOURCE: SPL-P100 calculator problem
There is a tab button that controls the amount of decimal places you would like. press tab and it will change to 0-2-3-4-A-F showing on the bottom of the screen.
It works. :-)
Joe Stogrin
www.littlejoesauctions.com
Posted on Jul 09, 2008
SOURCE: Canon P100-DH Calculator manual
Press the "calendar/clock" button to display the calendar. Then press the "=" sign to get the display to flash and you can enter the numbers for the date. Press the "=" sign again and you have set the date.
Press the "calendar/clock" button once or twice to display the clock. Then press the "=" sign to get the display to flash and you can enter the numbers for the time. Press the "X" button if you need to change the AM to PM or PM to AM. Press the "=" sign again and you have started the clock. Do this again if you need to start the clock again at zero seconds.
Posted on Sep 29, 2008
SOURCE: Viking V714 calculator tax rate change
1. Press C button
2. Press 1 then 5 button for the 15% VAT rate - 15 is shown on screen
3 Press SET Button
4. Press TAX+ button
5 Press = Button - 15.00 is shown on screen
All is done, check by doing:
C
100
TAX+
answer will be 115.00
Press TAX+ again- answer is 15.00
Posted on Dec 29, 2008
SOURCE: How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Posted on Jan 23, 2009
Why does my Canon MP49D calculator print light?
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
May 06, 2014 | Canon Office Equipment & Supplies
E shows on left of screen with 0 on right hand side. I can't get it to respond to any prompt.
sounds as if your calculator has registered a number to large to display. this can be done in either the normal calculating mode, or in the memory calculating mode. i will help with both scenarios.
for normal calculating mode:
try pressing the CE button and holding for about a half a second. the E should disappear and calculating function should resume.
if that doesn't work, try disconnecting power supply for a few seconds, then reestablishing power and hit CE
for memory calculating mode(there will be a M on the screen as well if this is the problem)
press either the CE or MC/MCE button for a half second. this should return normal function.
if that doesn't work, try the power reset as described above.
Jan 15, 2014 | Canon MP18D II Basic Calculator
Where is the reset buttun of algebra fx 2.0 plus calculater? i cant finf it
I need to know where I can purchase the plastic screen cover
on my canon mp49d calculator that displays the number. I
need to replace the one I have, it's cracked and i can't really see the numbers clearly. Can someone tell me where to purchase
this part without buying a new calculator.
Sep 23, 2013 | Office Equipment & Supplies
Calculation Wrong
Are you getting this wrong result both on the display and on the printout?
If it's just the display, I'd be tempted to suggest that you've got some bad display elements. Try multiplying 1111111.11 by 9. Do you get all nines, or do some threes show up?
Aug 30, 2013 | Canon MP49D Calculator
Replace paper
Follow the illustrated instructions on the first page of the manual at http://www.usa.canon.com/app/pdf/calculator/MP49D.pdf
Apr 26, 2013 | Canon MP49D Calculator
I need a manual for my new canon mp49d
You can download the manual from the manufacturer's web site at
Aug 17, 2011 | Canon MP49D Calculator
HOW DO I CHANGE THE HOUR TO AM AND NOT PM????
I cannot find a manual for the MP49D, so am using that for a similar calculator.
With the calculator turned on, press the time/calendar button twice. Now press and hold the "time set" button for three seconds. The display should show hours and minutes with the first character blinking, followed by an A or a P. Key in the time (if necessary to change it) using the number buttons, and press the AM/PM button to select A or P. When done, press the "time set" button again, then press the On/Clear button to return to calculation mode.
Feb 05, 2010 | Canon MP49D Calculator
Canon MP49D Calculator Logo
101 people viewed this question
old marine
old marine
