Question about Simplicity Sewing Machines
Help me thread my simplicity sewing machine/denim expert
SOURCE: A MANUEL FOR A SIMPLICITY SEWING MACHINE MODEL 237
To find the manual online goto simplicityhomecare.com. Under the PRODUCTS tab you'll see Instruction Manuals. Click on that and you'll have a choice of what machine you need an instruction manual for. Look under the Sewing Machine and you'll see the SL237 - Denim Expert. Hope this helps!!
Posted on May 01, 2008
talk2ginny
  • 34 Answers
SOURCE: thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Posted on Jan 31, 2009
  • 76 Answers
SOURCE: threading instruction for model #1220 simplicity
http://www.sewingstyle.com/Simplicity-Sewing-Manuals.htmlnot
not sure if you have the manual, try this site for a manual,
Posted on Sep 03, 2009
  • 22 Answers
SOURCE: I am looking for the power cord for the Simplicity
Try this online dealer:
http://www.sewingmachinesplus.com
Posted on Nov 10, 2009
  • 255 Answers
SOURCE: I have a Simplicity Denim
Hi. I believe your machine has a snap-on pressure foot. I've posted pictures of snap-on pressure feet at www.robbiesews.blogspot.com; just look for the 'pressure foot' tag or search the site for pressure feet and you shouldn't have any problem finding that post.
Anyway, there is an adapter (called an 'ankle') at the end of the 'long iron piece that lowers and raises the foot' (excellent description, BTW). The ankle attaches to that piece with a small thumb screw. With the ankle in place, you just lower the ankle onto the catch on the pressure foot.
You can also use regular low-shank feet on your machine. First, remove the ankle. The regular low-shank feet will attach to the raiser bar with that same thumb screw that holds the ankle in place.
You really should get a replacement manual for your machine. I found manuals for Simplicity sewing machines at http://www.sewingpartsonline.com/simplicity-sewing-machine-instruction-manuals.aspx.
Hope this helps!
Robbie
Posted on Aug 13, 2010
Free owers manual
your question is put under the sewing machine name of
simplicity denim star sw210, so that is the links I'm going to supply
for a manual,, but the manual is not free, I don't know where you can
get one for free
http://www.sewingpartsonline.com/instruction-manual-simplicity-sw210.aspx
http://www.sewingpartsonline.com/instruction-manual-simplicity-denim-star-sw210-download.aspx
Aug 06, 2012 | Simplicity Denim Star SW210
Not completly threading or something
i was told this is a timing problem
Feb 26, 2010 | Simplicity Denim Star SW210
Where to buy a replacement bobbin shuttle for a simplicity denim expert Model #237
The bobbin case should be a standard right hand finger which can be bought from most sewing machine shops
Oct 24, 2009 | Simplicity Sewing Machines
Simplicity Denim Star SW 210
Thread looping / bunching under fabric sewing.
Incorrect or NO top thread tension, Incorrect threading
Re thread top thread and thread machine with presser foot lifted allows thread to locate into the correct thread tension route.
Thread has not been pulled into thread tension unit- re thread, make sure thread is kept taut while threading.
Jan 03, 2008 | Simplicity American Denim SA1100...
Sewing Machines Logo
103 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
