Kodak carousel 650 slide projector won't advance
Won't advance
  • 1 more comment
  • Anonymous Dec 13, 2008
    Stephen , I also have a very old Kodak 600 slide pro. Have lots of slides in carosel's to view...the slides don't seem to get pushed up to rotate into place
    frustrated because nobody repairs locally. any luck?
  • lmr18 Jan 26, 2009
    my kodak 650 won't advance either. do you know where i can buy this part to replace?
  • bb608 Mar 04, 2009
    kodak carousel 650 slide projector won't advance
  • 33 Answers
Lmr18, if you are still looking for a source of parts, it would depend on where you are. If in the US, Google Fargo Enterprises Kodak. If in Canada, Doug banks Photo or email me at
Posted on Feb 20, 2009
  • 412 Answers
SOURCE: I bought a used kodak
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: We have a Kodak Carousel 650A projector. (140
The purpose of the "SELECT BAR" on a Carousel 650H is to eject the slide. If you press & hold the select bar it allows you to rotate the tray to the slide you want (or Zero & remove the tray). If you can not advance or reverse the slide tray using either the remote buttons or the buttons on the side of the projector, then chances are you have a broken part in the slide change mechanism. The possibilities are numerous, and really requires a trained tech to analyze your specific failure. Sorry the news isn't better (or simpler!).
Posted on Nov 12, 2010
  • 412 Answers
SOURCE: my slide projector carousel does not advance
Does the projector run in reverse?? If so, then what you are facing is a timing adjustment.
If it does not cycle in either direction, then there is a high probability that the solenoid "link" is broken. The "link" connects the cycle solenoid plunger to the slide change mechanism.
The good news: There are still parts available ( The less-than-good-news: both fixes are difficult and best handled by a factory-trained repair dealer.
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
  • 412 Answers
SOURCE: my kodak carousel 5600 slide
You are experiencing a fairly common problem called continuous cycling. It is caused by use or mis-adjustment.
If you feel comfortable with a electro-mechanical adjustment, take a look at the attached picture for the correct alignment of the cycle contacts. The positioning is critical for correct operation.
Turn the projector upside down (unplugged), and remove the bottom screws. Then carefully remove the bottom cover. The cycle contact assembly will be in the center of the projector.
If you need help, contact a authorized repair dealer. Good Luck!!
Posted on Aug 08, 2011
Staples won't advance and come out
There may be a piece of a broken staple jammed in the end or the spring may be weak
Apr 19, 2013 | Swingline 747 Classic Desk Stapler, 20...
How do I fix the Advance Lever if it is stuck?
Remove bottom cover and check for loose screw jamming the transport/cocking levers. Also check to make sure the advance shaft screw has not come loose.
Feb 13, 2013 | Vivitar V3800N 35mm SLR Camera
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
Im working on 2002 avalanche and it won't start
Pull your ignition module and take it to advance auto parts or autozone to have it tested.
Mar 06, 2012 | 2002 Chevrolet Avalanche
Timer won't advance
were there any written instructions with the new part?
Mar 01, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
Ribbon won't advance on its own
Try replacing the ribbon cartridge
Jan 16, 2012 | Brother GX-6750 Typewriter
My dryer quit heating and at the same time does not stop at the end of the cycle. Just keeps running. Is there something I can do to fix this problem?
If its on automatic cycle the timer won't advance if theres no heat. It will advance on timed cycle, though.
Sep 21, 2011 | Kenmore Dryers
Low battery icon on, won't recharge
Hi. If you do some research, you will find that this is a common issue with the Harmony One remote. I suggest using an elastic band to hold the remote firm onto the charger. That works for me.
Aug 03, 2011 | Logitech Harmony One Advanced Universal...
6,539 people viewed this question
